A In the power spectrum, why is the peak frequency at the first harmonic
The discussion centers on the concept of the first harmonic, commonly identified as the fundamental frequency, which typically has the highest energy emission. Participants clarify that harmonics are integer multiples of this fundamental frequency, and in some cases, higher harmonics can be stronger than the fundamental. The conversation also touches on specific examples, such as the Crab Nebula pulsar and clarinet sounds, where variations in harmonic strength occur. Additionally, the impact of the source's radiation characteristics on harmonic emissions is mentioned. Understanding these concepts is crucial for analyzing time series data in astrophysical contexts.
dave gannon
TL;DR Summary
I have being doing time series analyse of the crab nebula pulsar and cannot come up with a good answer for this question. any help would be greatly appreciated.
l
Astronomy news on Phys.org
Could you be a bit more verbose with your question please?
For instance, does First Harmonic mean Fundamental or does it mean First Overtone - or Second Harmonic? Are you referring to the variation with time? Show a graph perhaps?
Likes davenn
my thoughts exactly :smile:
if @dave gannon is referring to the fundamental freq. then this is where the most energy is being "emitted"D
dave gannon said:
Summary: I have being doing time series analyse of the crab nebula pulsar and cannot come up with a good answer for this question. any help would be greatly appreciated.
Welcome to the PF. :smile:
The "first harmonic" is more commonly referred to as the "fundamental" frequency. The harmonics are at 2x and 3x and ...x (integer multiples of) the fundamental frequency.
There are some cases where the harmonics are stronger than the fundamental. I'm not that familiar with such cases, but a simple Google search turned up a number of links to such cases. Here is one such link:
https://www.soundonsound.com/sound-...ocal-parts-harmonics-louder-fundamental-pitch
If the source is sending out radiation from each end as it rotates there will be two peaks every rotation. If the two output levels are not exactly the same then there will be a small amount of fundamental and a lot of second harmonic.
Likes DaveE
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
