Solve Incline Problem: Find Highest Point Reached by Block
  • Thread starter Thread starter milkyway11
    Incline
A block with an initial velocity of 2 m/s is projected up a frictionless incline at a 60-degree angle, and the goal is to determine the highest point reached. The discussion emphasizes using conservation of energy, equating kinetic energy at the bottom to potential energy at the top. The kinetic energy is represented as 1/2 mv^2, while potential energy is mgh, where h is the vertical height. Trigonometry is necessary to convert the incline distance to vertical height. The approach clarifies that understanding energy conservation simplifies the problem without needing to calculate acceleration directly.
milkyway11
question says: a block is given an initial velocity of 2m/s up a frictionless plane inclined at 60 degree to the horizontal. what is the highest point reached by the block?
I tried to figure out how to solve the problem by thinking in order to find the highest point, i need the distance it traveled then I can use the sin to find the height. However, in order to find distance traveled, I will have to find the acceleration up the incline and this is where I get stuck. I tried to use kinematics to find the acceleration knowing final velocity will be 0, but I don't know the time spent traveling so I can't solve for acceleration!
Please help me solve it!
Use conservation of energy.
At the top, the kinetic energy is 0 so it is all potential energy. At the bottom, it is all kinetic (if you set V=0 at that point). The two values are equal...hence 1/2 mv^2 at bottom = mgh at top, but that h is the vertical height, so you need to use trigonometry to find the distance up the incline...
Of course, the acceleration (if you do not know the conservation of energy theorem) is easy enough to find. The only force acting down the block is the accelaration due to gravity (taking into account trigonometry to find it's component down the incline...)
thank you, this helps a lot!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
