Understanding Negative Velocity: Is Increasing Velocity Always Positive?
In summary, velocity is the direction and speed of an object. When velocity is negative, it indicates the direction of motion is to the left.
Ryker
1,086
Increasing velocity, when velocity is negative
Basically, I just wanted to make sure I got this right. If velocity is negative, but the speed is decreasing, the velocity is increasing, right? On the other hand, if velocity is negative and is getting even more negative, then velocity is decreasing. Am I getting this right or is it the other way around?
First you need to be clear about velocity and speed.
Velocity has direction, and when you talk about positive and negative velocities, it usually just indicates the direction.
So, if a positive velocity is one to the right, then negative simply means the velocity is to the left, for example.
The positive and negative sign is not an indicator of whether or not the object is getting faster or slower, just which way it is moving.
The speed of the object is just "how fast" it's going. This is the numerical part of the velocity without the sign.
The measure of increase or decrease in a speed or velocity is acceleration.
To answer your question, when you say "velocity is negative" it simply indicates the direction of motion. (to the left, say). If the speed is decreasing, the object is getting slower. So, the object is moving to the left with a speed that is decreasing. Fine so far!
Put some example numbers to it...
t vel
1 -5
2 -4
3 -3
4 -2
This is velocity (m/s) over 4 seconds, showing the object getting slower in the direction to the left.
Yes, the numbers are increasing because they are getting less negative. So, technically, the velocity is increasing.
This is because the object is subject to an acceleration (+ive) in the direction to the right. Imagine it to be caused by friction, a force pointing to the right, against the motion to the left. A force to the right will produce an acceleration to the right.
Thanks, Stonebridge.
1. How is velocity measured on a graph?
Velocity is typically measured on a graph by finding the slope of the line at a specific point. This can be calculated by dividing the change in position by the change in time.
2. What factors can affect the velocity on a graph?
The velocity on a graph can be affected by various factors such as acceleration, mass, and external forces like friction or air resistance.
3. How can the velocity on a graph be increased?
To increase the velocity on a graph, you can either increase the acceleration or decrease the amount of time it takes to reach a certain point. Additionally, reducing external forces like friction can also increase velocity.
4. What does a steep slope on a velocity graph indicate?
A steep slope on a velocity graph indicates a higher velocity, meaning that the object is moving faster. This can be seen as a steeper incline on the graph.
5. Can velocity on a graph ever be negative?
Yes, velocity on a graph can be negative. This indicates that the object is moving in the opposite direction of the positive direction on the graph. For example, a car moving backwards would have a negative velocity on a graph.
  • Mechanics
  • Mechanics
