Do Indicator Functions Require Independence of Variables?
  • Thread starter Thread starter quema
    Functions
The discussion revolves around the relationship between two random variables, X and Y, and the expression involving their maximum, Z. It is clarified that the equation E(X-Y)max{X,Y} can be rewritten without assuming independence of the variables. A suggestion is made to adjust the inequality from <= to < to avoid double-counting when X equals Y. The conclusion emphasizes that the expression holds true for both dependent and independent variables, applicable to various types of distributions. The focus remains on the mathematical validity of the expression rather than the independence of X and Y.
quema
Hi,
If X and Y are two random variables. Let Z=max\left\{{X,Y}\right\}. Can I write:
E(X-Y)max\left\{{X,Y}\right\}=E(X-Y)X1_{\left\{{X\geq{}Y}\right\}}+E(X-Y)Y1_{\left\{{X\leq{}Y}\right\}}
Do I need to assume that both random variables are independent?
Thanks.
Hi quema! :smile:
I think you can always write that! I'm not sure what you're trying to do, though...
quema said:
Can I write:
Change the <= to < so you're not double-counting the case where X=Y, and it'll hold true regardless of dependence or whether they are discrete or continuous.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
