What Is the Correct Induced Charge on an Uncharged Conductor?
The discussion centers on the induced charge on an uncharged conductor, where one participant argues that the charge density on the bottom should be -η and on the top should be η, based on the induced charge rule. However, a classmate and tutor reference Gauss's law, concluding that the bottom charge density is actually -η/2. The tutor clarifies that the professor's answer aligns with this Gauss's law interpretation. The original poster realizes that the induced charge rule applies to grounded conductors, not isolated ones, leading to confusion in their initial reasoning. Ultimately, the understanding of the situation is clarified, emphasizing the distinction between grounded and uncharged conductors.
athrun200
The question itself is easy. E field at 2 is zero. E field at other points are of magnitude \frac{\eta}{2\epsilon}
But I am arguing with my classmate and tutor that what is the charge induced on the uncharged conductor.
For me, I simply use the rule induced charge (charge of same magnitude but different sign will be induced) to conclude that the charge density on the bottom of the conductor must be -\eta.
Since it is uncharged, the charge density on the top must be \eta.
But my classmate use Gauss law and obtain that the charge density on the bottom of the conductor is \frac{-\eta}{2}.
My tutor also said that the answer provided by professor is \frac{-\eta}{2}.
So why I can't apply the rule of induced cahrge here?
If the charge density on the top of the uncharged conductor was η, the field in region 1 would be η/ε which is not correct.
The rule of induced charge is applicable to grounded conductors. Here the uncharged conductor is isolated.
But it seems my question is a plane.
Sorry, my mistake. I edited the previous reply.
Thx a lot
I understand now
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
