Inductance between a polyurethane surface
  • Thread starter Thread starter JeffMandell
    Inductance Surface
Creating an electric circuit through a polyurethane surface involves using two electrodes separated by this dielectric material. Polyurethane is primarily an insulator, which means that while it can impede current flow, it does not inherently lose current; any current that flows in will equal the current that flows out in a steady state. However, energy loss may occur due to dielectric losses as the charge moves through the material. The discussion suggests that the setup resembles a capacitor more than an inductor, and practical measurement is recommended to assess the current behavior. Ultimately, while current may not be lost, energy dissipation can occur during the process.
JeffMandell
I am interested in creating an electric circuit that travels through a polyurethane surface. My plan is to set up two electrodes separated by the dielectric material.
My question to the wisdom of the internet is how much current will be lost through the polyurethane surface. I am looking for both a qualitative and a quantitative for me to fully understand.
Polyeurathane is an insulator? Your description suits a capacitor more than an inductor. Why not set it up and measure it?
If it conducts at all - no current will be lost through the surface.
The rate that charge enters one side is the same (steady state) as the rate that charge leaves the other side. It may lose energy on the way through though.
Indeed. Some types are used as potting/conformal coating compounds to add mechanical stability and improve physical shock resistance of electronic circuits.
You will be hard pressed to make a circuit small enough to 'travel through' any solid.
no current will be 'lost'. [If it 'goes missing', you can find it.]
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
