Inequality or just wrong? (algebra practice)
  • Thread starter Thread starter Tyrion101
    Inequality
Tyrion101
I've been making up problems to practice with, and I came across something I couldn't tell on my own, and that is, how do you know that your problem is supposed to be an inequality or you did something wrong? Should I just be looking up other peoples problems instead to try and practice with?
Mathematics news on Phys.org
Without any specifics it would be very hard to answer your question.
if you can plot your answer then you can test a point on one side of the line of equality and then on the other side of the line. (assuming you have a line or bounding curve).
That could work for two-dimensional (three-dimensional, if you're really good at visualization) problems. However, I advise that you try to algebraically manipulate your problem, because often you will not be able to plot your "equation" on a graph.
You can regard the stated inequality as a HYPOTHESIS.
Going through steps for solving it, by simplifying it in a logically valid manner will REVEAL if the hypothesis was true or false.
However, if your initial inequality is too complicated, say non-linear, you might never be able to prove the truth or falsity of it.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
