Inequality rational polymonial
The discussion centers on solving the inequality (3x+1)/(x+4) ≥ 1. The initial approach incorrectly assumed x+4 was always positive, leading to the conclusion x ≥ 3/2. A more accurate method involves breaking the problem into cases based on the sign of x+4, resulting in two solution sets: x < -4 and x ≥ 3/2. An alternative solution method suggested multiplying by (x+4)² to avoid changing the inequality sign, ultimately leading to the same conclusion. The key takeaway is the importance of considering the sign of expressions in rational inequalities.
xzi86
(3x+1)/(x+4)>=1
(3x+1)>=(x+4)
2x>=3
x>=3/2
But this is wrong?? Why?
If you multiply both sides of an inequality by a negative number, you reverse the direction of the inequality. But you don't know whether x+ 4 is positive or negative.
Instead break it into two parts. x+ 4 is positive, that is x+ 4> 0 for x> -4. If that is the case, then 3x+1> x+ 4 so that 2x> 3, x> 3/2. Because any value of x that is larger than 3/2 certainly is larger than -4, x>= 3/2 is part of the solution.
But if x< -4, then x+ 4 is negative. And then 3x+1< x+ 4 so that 2x< 3 so that x< 3/2. Now we argue the other way: any number that is less than -4 certainly is less than 3/2 so x< -4 is the other part of the solution. (x= -4 is not because the fraction is not defined if x= -4.)
You can check: if x= -5, then 3x+1= -15+1= -14, x+ 4= -1 so that (3x+1)/(x+4)= -14/-1= 14 which is certainly greater than 1.
That is, the solution set is all values of x less than -4 and all values of x greater than 3/2.
so my method was good except i forgot to consider x is negative
Not x is negative, but x+4 is negative, or x+4<0, x<-4.
Another way to solve this problem without considering cases is to multiply by (x+4)2 because any number squared is always positive, so there is no need to switch the inequality sign. You have to solve a quadratic and you'll get the same answer.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
