Inertial vs Gravitational Mass
Gravitational mass determines the force of attraction between massive objects, while inertial mass is related to an object's resistance to acceleration when a force is applied, as described by F=ma. The equality of gravitational and inertial mass is not inherently necessary, but experimental evidence suggests they are equal since all objects accelerate at the same rate under gravity, regardless of mass. This observation implies that if they were not equal, heavier objects would fall differently than lighter ones, contradicting experimental findings. The discussion highlights the significance of this equality in understanding fundamental physics. Overall, the relationship between inertial and gravitational mass is a crucial aspect of gravitational theory.
Abtinnn
Hi!
Could someone please explain the difference between gravitational and inertial mass? And how are they equal?
Thank you!
You need a force to accelerate an object because of its inertial mass.
Inertial mass is the "m" in F=ma.
Gravitational mass is a property of massive objects that governs their force of attraction in gravity.
There is no reason that these two have to be equal a priori, but there are very good reasons to believe this is so.
The best reason I can come up with, is that in the absence of all other forces, the acceleration of an object due to gravity doesn't depend on its mass (so far as we can tell experimentally).
If gravitational and intertial mass were not equal, then more massive objects would fall at a different acceleration than less massive objects (not counting air drag and such).
Likes Abtinnn and PFuser1232
Thanks a lot! :D
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
