Input a micro controller into Eagle circuit 6.2.0 light
To integrate the ATMEGA168A-PU microcontroller into Eagle 6.2.0 Light, users may need to create a custom library as the specific component is not readily available. A generic 40-pin DIP footprint can be utilized, which requires manual wiring from the schematic to the PCB footprint. Users are encouraged to refer to Eagle's tutorials for guidance on creating and managing components. The process may involve some trial and error, but resources are available to assist. Overall, creating a custom footprint and wiring it correctly is essential for successful integration.
jstbyndjupitr
I'm trying to pull in an ATMEGA168A-PU Atmel 8 Bit 16K AVR Microcontroller into Eagle and have looked through the libraries provided through their website, does anyone know where i can find it or and equivalent controller?
You'll probably need to create your own. Should be a generic footprint for a 40-pin DIP (assuming that's what you have) that you can probably copy and use for your own (you still need to do the 'wiring' from the schematic part to the PCB footprint). Since it's been a while since I've used Eagle, and since they'd do a better job of it anyway, this is covered in the tutorial:
http://www.cadsoftusa.com/training/tutorials/
Thanks, I'll give it a shot!
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 26 ·
