Input Power against time graph - Flywheel rest to 300rpm
The discussion revolves around a homework problem involving a gearbox and flywheel system, specifically focusing on calculating input torque, holding torque, and plotting input power against time as the flywheel accelerates from rest to 300 RPM. The scope includes theoretical calculations and practical applications of physics principles related to rotational motion and power dynamics.
  • Homework-related
  • One participant seeks help with plotting the input power against time, expressing uncertainty about how to approach this part of the problem.
  • Another participant notes the relationship between input torque, RPM, and power, suggesting that power varies with RPM if torque is constant.
  • Several participants discuss calculating angular velocity and acceleration, with one participant attempting to derive angular speeds at various time intervals and questioning how to relate these to input power.
  • There is a discussion about the correct method to calculate time and angular acceleration, with one participant initially misunderstanding the relationship between angular velocity and time.
  • One participant expresses confusion over the calculations for input and output torque, indicating a struggle to differentiate between the two in their calculations.
  • Another participant asks about the assumptions made in calculating gearbox torque, specifically regarding efficiency and power dissipation.
Participants generally share similar approaches to the problem but exhibit uncertainty and confusion regarding specific calculations and relationships between variables. There is no consensus on the best method to plot the input power against time, and multiple viewpoints on how to derive the necessary values are present.
Some participants mention using kinematic equations and the moment of inertia in their calculations, but there are unresolved questions about the correct application of these concepts, particularly in relation to torque and power. The discussion reflects varying levels of understanding and assumptions about the relationships between angular acceleration, torque, and power.
Students working on similar physics problems involving rotational dynamics, torque, and power calculations may find this discussion helpful.
Moranovich
Hello,
A gearbox and flywheel are as shown in FIGURE 4. The output shaft
rotates in the opposite direction to the input shaft at 5 times its speed.
The gearbox has an efficiency of 92%.
If the flywheel is solid, has a mass of 50 kg, a diameter of 1.5 m and is to
accelerate from rest to 300 revs min–1 in 1 minute:
(a) Calculate the torque required at input T1.
(b) Calculate the magnitude and direction of the torque required to hold
the gearbox stationary (holding torque Th). Show the direction of the
holding torque applied to the shaft with the aid of a sketch.
(c) Plot a graph of the input power against time when taking the
flywheel from rest to 300 revs min–1.
I am having trouble with (c) not sure how to tackle this part have all the answers for (a) and (b)
No idea please help.
Regards.
What's the relationship between input torque, RPM, and power?
Thanks for your reply.
P=T. angular velocity
I was thinking today I have worked out the input torque and input power required when the output shaft is at 300rpm so do I work out the input power from 60rpm down to 0 I.e at rest. But how can I do this if I only know the rpm eg 50,40,30etc to zero and don't know power or torque?
Where does time come in is it to do with the revolutions per minute?
Your help is much appreciated.
If your input torque is constant, then the power input is obviously going to vary as the RPM versus time. Knowing what your angular acceleration is as a function of time, you should be able to calculate angular velocity as a function of time as well as the power.
Ok so I worked out my constant acceleration from this kinematic equation
final ang speed=initial ang speed + acceleration . time using 60sec as per question for time. Then using the constant acceleration figure I changed the time in the equation to 5sec.10sec etc to work out all the angular speeds.
Now do I multiple these angular speeds against my Torque constant to get the Input power values?
Also seems to be that the equation to find the time is t=angular speed/constant acceleration
Thanks again.
You were doing fine, then you suddenly veered off the rails.
t is not found by dividing ang. vel. by ang. acc. (where did you learn that?)
t is the independent variable. The ang. acc.of the flywheel is the moment of inertia of the flywheel divided by the torque. For a constant torque, the ang. acc. is constant.
The ang. vel. as a function of time is the initial velocity (or 0 since the flywheel starts at rest) plus the ang. acc. times t. Remeber, you are being asked to make a graph of input power v. time while the flywheel accelerates to 300 RPM.
Therefore, for various t values, you need to calculate the current ang.vel. and the resulting power so that you can make this plot.
I had worked out the ang. vel for each 5 sec interval and then was messing around to check it and input ang. vel for 300rpm divided by acceleration to get the time taken. So 10pi/0.167pi = 59.98sec ...
So is how I worked out each ang. vel correct?
i.e final ang vel=initial and vel + acceleration . time
eg 10pi=0 + 0.167pi . 60
or for 20sec ang vel= 0 + 0.167pi . 20
therefore after 20s ang vel=10.49rads^-1
Then just multiple these ang. vel figures against my Input Torque figure?
When I do as you suggested -
This gives me the figure I had worked out for the Output shaft Torque not the Input shaft Torque value!
Think I am tying myself in knots ...
Disregard above I was getting confused.
So dividing my moment of inertia by Output shaft Torque = 1.91rads^-2
So initial vel 0 + 1.91 . 60s =114.6
Hello Steamking,
Thanks very much for your help the penny has finally dropped!
I think I wouldn't have got there if you hadn't of pointed me in the right direction.
Thanks again much appreciated.
Doing the same question now alas, for part B did you calculate the gearbox torque magnitude via the assumption that it dissipates 8% of the initial power?
Or just via the assumption that T(Driver) = T(Acceleration) + T(Frictional) which semi amounts to the same thing.
Moranovich said:
Hello,
Regards.
How did you work out B mate?
  • · Replies 18 ·
9K
