- #71
OmCheeto
- 2,939
mfb said:Temperature is a huge problem. Let's take @OmCheeto's dirty towel (I found a towel the same mass, and could reproduce the numbers):
We have 130 grams of water. It will start to freeze as soon as we lower the temperature by 20 K. That is sufficient to evaporate ~1/25 of the total mass, or about 10 grams. We get roughly 20-30 grams more to evaporate before all the water is frozen. Doesn't work.
We can start by heating the towel, but not enough to get rid of the whole water by evaporation without freezing some. Multiple vacuum cycles with hot air in between could work, but that doesn't sound efficient.
A pressure below atmospheric pressure, but sufficient to still deliver heat all the time?
I'm not even sure if evaporation at room temperature and vacuum can beat evaporation at dryer temperatures and atmospheric pressure.
I have completed my calculations, and came up with a similar conclusion.
The amount of energy to dry clothes in a vacuum is roughly the same as at atmospheric pressure.
For 4.6 kg of water, I had to add 2.9 kwh of energy to maintain the temperature.
Fun project!
I think I'll look into dryer heat exchangers now.
This guy seems to have only one serious design flaw:
http://www.builditsolar.com/Experimental/DryerHX/DryerHXTest1.htm
Dryer into HX, 136°F
Dryer out of HX, 88°F
Room into HX, 79°F
Room out of HX, 95°F
But even with the flaw, I think it's pretty impressive; "The heat exchanger, as it is, saves about 32% on the total energy used"Dryer out of HX, 88°F
Room into HX, 79°F
