The powder is CuCl. PVC is 60% chlorine which provides the catalyst for the change, and the location of the wire provided the environment. The copper wire at some point heated to over 450C and reacted with the chlorine in the PVC. This is much more likely to happen in stranded wire, especially improperly protected stranded wire, as a pinch point or other mechanical force exerted on the wire can cause strands to break inside the sheathing, increasing the wire's resistance and decreasing its heat dissipation.
Interestingly enough, the combination of copper wire and PVC sheathing makes for an effective yet presumably unintentional fail safe. In the event of a runaway overload, the chlorine will react with the copper, opening the circuit before the copper can melt and the other layers of pvc reach its melting point.
