Integral and Partial fractions
The discussion focuses on solving the integral using partial fractions for the expression 36/((x-2)(x-1)^2(x+1)^2). The user initially set up the equation for partial fractions but included an extra factor in the terms, leading to confusion. Clarifications were provided on correctly multiplying both sides by the common denominator to simplify the equation. The user successfully determined some constants (A, C, E) but struggled to find B and D, prompting suggestions to substitute specific values for x to create solvable equations. The thread concludes with encouragement to continue solving the equations for the remaining unknowns.
jimen113
use the method of partial fractions on \int \frac{36}{(x-2)(x-1)^2(x+1)^2} dx
2. Homework Equations
3. The Attempt at a Solution
\frac{A}{(x-2)} + \frac{B}{(x-1)} + \frac{C}{(x-1)^2} + \frac{D}{(x+1)} + \frac{E}{(x+1)^2}
I took the 36 out of the integral. Then
A(x-1) (x-1)^2 (x+1) (x+1)^2 + B(x-2) (x-1)^2 (x+1) (x+1)^2 + C (x-2)(x-1) (x+1) (x+1)^2 + D(x-2) (x-1) (x-1)^2 (x+1)^2 + E (x-2)(x-1) (x-1)^2 (x+1) =1
In the first fraction (A) (all terms cancel)
I tried to plug in x=
1, -1, 0, 2, -2, into (A(x-1) (x-1)^2 (x+1) (x+1)^2 + B(x-2) (x-1)^2 (x+1) (x+1)^2 + C (x-2)(x-1) (x+1) (x+1)^2 + D(x-2) (x-1) (x-1)^2 (x+1)^2 + E (x-2)(x-1) (x-1)^2 (x+1) =1)
so...
when x=1 I ended up with B(-2) +C(-4)=1 (I know this is probably simple algebra or I'm definitely screwing up somewhere
Any help is appreciated
Why do you have this extra factor (x+1) in front of everything? For example for A you would get:
\frac{A}{x-2} (x-2)(x-1)^2(x+1)^2=A (x-1)^2(x+1)^2. You have added an extra (x+1) and you're doing that for every term it seems.
You start out with:
\frac{A}{x-2}+\frac{B}{x-1}+\frac{C}{(x-1)^2}+\frac{D}{x+1}+\frac{E}{(x+1)^2}=\frac{1}{(x-2)(x-1)^2(x+1)^2}
right?
Then multiply both sides with the denominator of the right hand side.
A(x-1)^2(x+1)^2+B(x-2)(x-1)(x+1)^2+C(x-2)(x+1)^2+D(x-2)(x-1)^2(x+1)+E(x-2)(x-1)^2=1
Now set x=1 \Rightarrow C=-\frac{1}{4}, x=2 \Rightarrow A=\frac{1}{9} etc.
You made the mistake over here:
Code:
Because you multiple the separate fractions by the common denominator, it would end up as
A(x-1)^2 (x+1)^2 + B(x-2)(x-1)(x+1)^2 + ... + E(x-2)(x-1)^2 = 1
Thank you so much for your help zcd and cyosis. Last question: I get A= (1/9) C=(-1/4)
E=(-1/12)
But to find D and B I tried plugging in zero and didn't get anywhere. What other numbers can I plug into solve for D and E? :blushing:
You will have to pick two values such that B and D aren't multiplied by zero. Since you know all the other constants you will get two equations relating B to D. Solve them and you're good to go.
omg...thank you for your help...
I did try plugging in (-2) and I end up with:
1+B(12)+1+D(36)+3=1
and B(12)+D(36)=-4
so I'm still left with the two unknowns...
Try x=0 this will give you 1/9+2B+1/2-2D+1/6=1, -> B-D=1/9. You now have two equations and two unknowns so it is solvable.
thanks.
  • · Replies 105 ·
