Integral and Partial fractions
The discussion revolves around the application of the method of partial fractions to the integral \(\int \frac{36}{(x-2)(x-1)^2(x+1)^2} dx\). Participants are exploring how to decompose the integrand into simpler fractions.
  • The original poster attempts to set up the partial fraction decomposition but questions arise regarding the inclusion of an extra factor in their expressions. Participants suggest verifying the setup and simplifying the equations.
Participants are actively engaging in clarifying the setup of the problem and correcting misunderstandings. Some have provided specific values to substitute in order to solve for unknown coefficients, while others are discussing the implications of their choices on the equations formed.
There are constraints regarding the choice of values for substitution to avoid zero multipliers for certain coefficients. The original poster is seeking additional values to resolve remaining unknowns.
jimen113
use the method of partial fractions on \int \frac{36}{(x-2)(x-1)^2(x+1)^2} dx
2. Homework Equations
3. The Attempt at a Solution
\frac{A}{(x-2)} + \frac{B}{(x-1)} + \frac{C}{(x-1)^2} + \frac{D}{(x+1)} + \frac{E}{(x+1)^2}
I took the 36 out of the integral. Then
A(x-1) (x-1)^2 (x+1) (x+1)^2 + B(x-2) (x-1)^2 (x+1) (x+1)^2 + C (x-2)(x-1) (x+1) (x+1)^2 + D(x-2) (x-1) (x-1)^2 (x+1)^2 + E (x-2)(x-1) (x-1)^2 (x+1) =1
In the first fraction (A) (all terms cancel)
I tried to plug in x=
1, -1, 0, 2, -2, into (A(x-1) (x-1)^2 (x+1) (x+1)^2 + B(x-2) (x-1)^2 (x+1) (x+1)^2 + C (x-2)(x-1) (x+1) (x+1)^2 + D(x-2) (x-1) (x-1)^2 (x+1)^2 + E (x-2)(x-1) (x-1)^2 (x+1) =1)
so...
when x=1 I ended up with B(-2) +C(-4)=1 (I know this is probably simple algebra or I'm definitely screwing up somewhere
Any help is appreciated
Why do you have this extra factor (x+1) in front of everything? For example for A you would get:
\frac{A}{x-2} (x-2)(x-1)^2(x+1)^2=A (x-1)^2(x+1)^2. You have added an extra (x+1) and you're doing that for every term it seems.
You start out with:
\frac{A}{x-2}+\frac{B}{x-1}+\frac{C}{(x-1)^2}+\frac{D}{x+1}+\frac{E}{(x+1)^2}=\frac{1}{(x-2)(x-1)^2(x+1)^2}
right?
Then multiply both sides with the denominator of the right hand side.
A(x-1)^2(x+1)^2+B(x-2)(x-1)(x+1)^2+C(x-2)(x+1)^2+D(x-2)(x-1)^2(x+1)+E(x-2)(x-1)^2=1
Now set x=1 \Rightarrow C=-\frac{1}{4}, x=2 \Rightarrow A=\frac{1}{9} etc.
You made the mistake over here:
Code:
Because you multiple the separate fractions by the common denominator, it would end up as
A(x-1)^2 (x+1)^2 + B(x-2)(x-1)(x+1)^2 + ... + E(x-2)(x-1)^2 = 1
Thank you so much for your help zcd and cyosis. Last question: I get A= (1/9) C=(-1/4)
E=(-1/12)
But to find D and B I tried plugging in zero and didn't get anywhere. What other numbers can I plug into solve for D and E? :blushing:
You will have to pick two values such that B and D aren't multiplied by zero. Since you know all the other constants you will get two equations relating B to D. Solve them and you're good to go.
omg...thank you for your help...
I did try plugging in (-2) and I end up with:
1+B(12)+1+D(36)+3=1
and B(12)+D(36)=-4
so I'm still left with the two unknowns...
Try x=0 this will give you 1/9+2B+1/2-2D+1/6=1, -> B-D=1/9. You now have two equations and two unknowns so it is solvable.
thanks.
  • · Replies 105 ·
