Integral of 5x^2 /sqrt(4x-x^2) dx
  • Thread starter Thread starter s3a
    Dx Integral
The integral of 5x² / √(4x - x²) dx requires a specific approach involving completing the square and trigonometric substitution. The incorrect squaring of the integrand led to confusion, as it alters the integral's value. The correct method involves rewriting the expression under the square root as -(x - 2)² + 4, followed by a substitution u = x - 2 and then applying the trigonometric substitution 2sin(θ) = u. This structured approach ensures accurate integration and avoids common pitfalls.
  • Understanding of integration techniques, specifically variable substitution.
  • Familiarity with trigonometric identities and substitutions.
  • Knowledge of completing the square for quadratic expressions.
  • Basic differentiation principles to verify integrals.
  • Study the method of completing the square in algebraic expressions.
  • Learn about trigonometric substitution in integrals, focusing on cases involving square roots.
  • Explore the concept of integrals and their properties, particularly how transformations affect the integrand.
  • Practice solving integrals using variable substitution and verify results through differentiation.
Students studying calculus, particularly those tackling integration problems, as well as educators seeking to clarify integration techniques involving trigonometric substitutions and variable manipulation.
s3a
Integral of 5x^2 /sqrt(4x-x^2) dx. (This can also be seen in the attached TheProblem.png file.)
Integration with variable substitution.
Could someone please tell me what I did wrong in my work (which is attached as MyWork.jpg)?
You can't do what you did when you squared the integrand. IOW, in the step where the integrand changes from ## \frac{5x^{3/2}}{\sqrt{4 -x}}## to ##\frac{25x^3}{4 - x} ##.
Ouch why would anyone ever make you solve this. You have to complete the square, then do a trig sub, followed by a bunch of manipulation of variables.
I don't know if this is answerable in a way other than “you just can't” but, why can't I do that?
[Dark Knight movie quote]Some men just want to see the world burn.[/Dark Knight movie quote] :P
But, on a serious note, are you saying to make what's under the root be -(x-2)^2 + 4?
Because, in general ##\int f(x)dx \neq \int [f(x)]^2 dx##. When you square the integrand, you get a different integrand.
That seems to be what iRaid was suggesting.
Oh, is it because squaring (or something similar) yields volumes?
Alright. :) So, is my latest attachment correct so far?
No, nothing to do with that. If you square something, what you get is usually different. You wouldn't expect the integral to remain the same, would you?
Looking at it another way, do you think that d/dx(x2) = d/dx(x4)?
You can check for yourself. If you differentiate your answer, you should get back your original integrand.
No but, I think I see a better way of understanding it; 3/4 ≠ 3^2 / 4^2 = 9/16 so, integrating each yields a different answer (and, it's different from squaring both sides of an equation).
I don't see how I can bring back the square root plus, Wolfram Alpha seems to imply that the two expressions are NOT equal … where have I gone wrong this time? It's probably something small like the squaring of the numerator and denominator from last time but, I just can't see what it is!
In your latest work, it looks like you just swapped dx for dθ to get the new integral. If that's what you did, that's where you went wrong. If 2sinθ = x - 2, then dx = 2cosθdθ.
Also, in you latest work, you have 5x3 in the numerator - it should be 5x2.
After completing the square, you should have this integral:
$$ \int \frac{5x^2 dx}{\sqrt{4 - (x - 2)^2}}$$
At this point I would bring the 5 outside the integral, and would do an ordinary substitution with u = x - 2. Then I would do the trig substitution, with 2sin(θ) = u and 2cos(θ)dθ = du.
I now see how to do that problem! Thank you (both) very much!
  • · Replies 44 ·
  • · Replies 105 ·
  • · Replies 54 ·
15K
