Integrate (1+Z)/(2-2Z): Step-by-Step Guide
  • Thread starter Thread starter franky2727
    Integration
18 replies · 3K views
franky2727
how do i integrate (1+Z)/(2-2Z)
What have you tried so far?
substitute 2-2Z for u? but then I've still got something over something else and still don't get what method to use :S
As HallsOfIvy pointed out, you can just use polynomial long division to decompose the fraction into something more integrable.
If u=2-2Z then Z=(2-u)/2. Substitute that into 1+Z. Now it's all u's.
Dick said it all. You need to write Z in terms of u, then you need to find dz/du by differentiating that. You substitute everything in and integrate.
If you factor out the 2, sub u = 1-z and z = 1-u, all the work has been done for you. Just separate the fraction and integrate.
If you substitute [itex]u=2-2z[/itex], and you simplify it, you will end up with this at one point:
[itex]-\frac12 \int \left( \frac{2}{u} - \frac12 \right) \ \mathrm{d}u \implies \frac14 \int 1 \ \mathrm{d}u - \int \frac{1}{u} \ \mathrm{d}u[/itex]
Integrate this and remember to substitute [itex]u=2-2z[/itex] in the end to get the final answer.
[tex]u = z-1[/tex]
[tex]du = dz[/tex]
[tex]z = u + 1[/tex]
[tex]\frac{1}{2} \int \frac{1+z}{1-z}dz =\frac{1}{-2} \int \frac{1+z}{z-1}dz =[/tex]
[tex]\frac{1}{-2} \left( \int \frac{dz}{z-1} + \int \frac{z}{z-1}dz \right) =[/tex]
[tex]\frac{1}{-2} \left( \int \frac{du}{u} + \int \frac{u + 1}{u} du \right) =[/tex]
[tex]\frac{1}{-2} \left( \int \frac{du}{u} + \int \frac{du}{u} + \int du \right) =[/tex]
Continue from this point.
And if you use the fact that [tex]\frac{1+z}{2-2z}= -\frac{1}{2}\left(1+ \frac{1}{1-z}\right)[/tex] you have
[tex]\int \frac{1+z}{2- 2z}dz= -\frac{1}{2}\int (1+ \frac{1}{z-1}dz= -\frac{1}{2}(z+ ln|z-1|)+ C[/tex]
That seems simpler to me.
Your method is indeed much simpler. =)
That's false though... Just check z=0 the left side gives 1/2, but the right side gives -(1/2)(2)=-1...
At this point I'm wondering who cares. franky2727 hasn't checked in since the initial post. I guess this thread is just getting a lot of attention because nothing else is going on.
