Integrating f(x) with Trapezium Rule & Plotting for Different Values of C
The discussion focuses on integrating the function f(x) = x^3 + tan(x) + C using the trapezium rule between x = 2 and x = 4 with a step size of 0.1. The original code successfully calculates the integral but fails to plot results for varying values of C. A solution was provided, suggesting the addition of an outer loop to iterate through different C values and store the area results in an array. The modified code allows for plotting all calculated areas on the same graph. This approach effectively addresses the plotting issue while maintaining the integration calculations.
Rachelross
Write a script file to integrate the function f(x)=x^3+tan(x)+C using the trapezium rule.Calculate the integral between the end points x=2 and x=4 with strip size 0.1.Calculate the integral for range of values from 1 to 3 in steps of 0.1.plot the integral obtained for different values of C?
I wrote the code and it is calculating the correct integrals but it is not plotting the integrals obtained for different values of C .can u please help me to modify my code so that it plots :)
This is my code that I have been working on:
% What are the integration limits?
clc
a = 2;
b =4;
% What is the integration step size?
dx = 0.1;
% An array containing the x points.
x = [a:dx:b];
% What is the function to integrate?
C=1:0.1:3;
C;
y =x.^3+tan(x)+C;
% The number of points
N = length(y);
%initialise the area variable
sum_y = 0;
%sum the interior elements of the y array
%note how the loop starts at 2 and stops at N-1
for I = 2:N-1
sum_y = sum_y + y(I);
area = dx*((y(1) + y(N))/2 + sum_y)
plot(area,C)
end
Thank you for your help:)
Hi it seems to me that you have find area for different values of C. For every value of C, you have to integrate and find area, this needs outer 'for' loop. To plot the result the variable 'area' should be an array. I have modified your program slightly as given below.
clc
a = 2;
b =4;
dx = 0.1;
x = [a:dx:b];
for C=1:0.1:3; % This loop to find area for different values of C
y =x.^3+tan(x)+C;
N = length(y);
sum_y = 0;
i=1; % index to store area in an array
for I = 2:N-1
area (i)= dx*((y(1) + y(N))/2 + sum_y); % variable area is an array
i=i+1;
end
plot(area);
hold on % To plot areas for different values of C on same graph
end
Hope this helps
Thank you so much n.karthick :)
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
