Integrating square to triangle?
To integrate a square wave using an op-amp, the standard formula V_{out} = -\frac{1}{RC}\int V_{in} dt must be applied correctly. The issue arises because integrating over one full cycle results in zero due to the symmetry of the square wave. Instead, the integration should be performed over a variable time t to obtain a function of t, which will yield a triangle wave output. To determine the appropriate resistor and capacitor values for a desired output amplitude of 5V and frequency of 200Hz, any ratio of R and C can be chosen as long as their product meets the necessary criteria. Ultimately, selecting arbitrary values for R and C that satisfy the equation will solve the problem.
Exulus
Hi guys, I need a bit of help with this. I've got an op-amp and the standard formula:
And i need to integrate a square wave from it in order to determine some capacitor/resistor values to get an output amplitude of 5V and freq 200Hz (triangle wave). Every time i try to do it i end up getting 0 as an answer (which is kind of logical, considering one half of the cycle is the negative of the other). For example:
V(t) = V for 0 \leq t \leq 0.0025
V(t) = -V for 0.0025 \leq t \leq 0.005
V_{out} = -\frac{1}{RC} [ \int_{0}^{0.0025}Vdt - \int_{0.0025}^{0.005}Vdt]
V_{out} = -\frac{1}{RC} (0.0025V - (0.005V - 0.0025V)) = 0
How can i get around this problem? Cheers.
V_{out}(t) = -\frac{1}{RC} (0.0025V - (0.005V - 0.0025V)) = 0
If you calculate the integral for an entire cycle of the wave you get the area under the curve that is of course 0. What you want is not the integral of one period, but the integral from 0 to a time t, that is a function of t.
V_{out}(t) = -\frac{1}{RC} [ \int_{0}^{t}V(τ)dτ
The function Vout(t) is a triangle wave.
If in the function Vout(t) you replace t by 0.005 you get 0, the value of the integral you have calculated.
edited to inform:
I don't know what happened. Where appears the number 964, there should be the greek letter τ (tau)
SGT, it looks like you used the symbol for tau; however, you have to use \tau in latex. Maybe the latex code on the server messed things up here... 964 is the HTML reference to the greek letter tau.
V_{out}(t) = -\frac{1}{RC} [ \int_{0}^{t}V(\tau)d\tau
Since I cannot anymore edit my previous post, I am posting again with the corrections provided by faust9. Thank you, Faust.
Cheers, i still really don't get what i need to do though. I've got the function for a square wave as stated above, but how do i go about finding an expression for R and C? I know they can pretty much be unlimited as i will just get a ratio between them but i don't really see how i can go about getting that ratio...im completely lost :(
You just choose some arbitrary values, J. Doesn't matter as long as the product of the two makes the right number.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
