Integrating the area under a curve
To integrate the area under the curve defined by the functions \(\frac{x}{3x}\) and \(\frac{x}{3\sqrt{x}}\) between x=1 and x=4, it is crucial to simplify the fractions first, factoring out \(\frac{1}{3}\). After simplification, the integral becomes \(\frac{1}{3}\int_1^4 (x^{1/2} - 1)dx\). A common mistake is miscalculating the integral, particularly in the evaluation of \(x^{1.5}\) which should be computed as \(\frac{x^{1.5}}{1.5}\) rather than \((\frac{x}{1.5})^{1.5}\). The final correct answer for the integral is approximately \(\frac{5}{9}\), which aligns with the area under the curves.
Luke77
Hey everyone, I had a recent post similar to this one, and everyone may have not understood it because I didn't use LaTeX, so here it is.
Integrate the area under \frac{x}{3x} and above \frac{x}{3x^.5} between x=1 and x=4.
Same as: \int \frac{x}{3x} - \frac{x}{3x^.5} dx between x=1 and x=4.
See above
I would integrate each individual fraction by raising each by 1 power, and dividing the coefficient by that new exponent. Each time that I try this, no matter how I simplify it, the answer turns out to be way too small.
What should I try next?
See above
Before integrating, you really should simplify the fractions. Both fractions have a factor of 1/3, so that should be factored out and brought out front of your integral.
After simplification, what does your integral look like?
Tip: itex is used for inline expressions, but it makes fractions and integrals very small. For those kinds of things use tex instead of itex.
Factoring's not my strong topic:
\frac{1}{3}\int 1 - \frac{x}{x^.5} dx between 1 and 4
\frac{1}{3}\int 1 - \frac{x}{x^{.5}} dx between 1 and 4
\frac{x^1}{x^{.5}} = x^{.5}
So your integral should look like this:
$$ \frac{1}{3}\int_1^4 1 - x^{1/2}~dx$$
And from there, just regularly integrate?
Thank you so much Mark
Yes.
Actually, one last question. Why do when I compute it, it is a negative number? Is there any rules I should be aware of... I just started learning about Calculus and the definite integral.
Specifically, -1.667
Luke77 said:
1. Homework Statement [/b]
could be a problem regarding the area below 1/3 and above √x/3, but as x varies from 1 to 4, √x/3 varies from 1/3 to 2/3, so the setup doesn't make much sense.
The integral should be
## \frac{1}{3}\int_1^4 x^{1/2} - 1 ~dx##
The graph of y = (1/3)x1/2 lies above the graph of y = 1/3 on the interval [1, 4]. When you measure a distance, you need to subtract the smaller number from the larger number, otherwise you'll get a negative value for the length of the typical area element.
Thank you very much Mark!
My final answer came out to be 1/3, does that sound right?
No, you have made a mistake. Show us what you did to get 1/3 for your answer.
I see what I did. Let me try it again:
\frac{1}{3}\int (x^.5 - 1)dx
= \frac{1}{3} ((\frac{x}{1.5} ^1.5) - x)) for 1 through 4
= \frac{1}{3} (\frac{4}{1.5} ^1.5) - 4) - (\frac{1}{1.5} ^1.5 - 1))
=\frac{1}{3} (((2.66^1.5) - 4) - ((.66^1.5) - 1))
=1/3((4.338-4)- (.536 - 1)) = 1/3(.338 + .464) = 1/3(.802) = .267
= \frac{1}{3} ((\frac{x}{1.5} ^1.5) - x)) for 1 through 4= \frac{1}{3} (\frac{4}{1.5} ^1.5) - 4) - (\frac{1}{1.5} ^1.5 - 1))
Here is your error. The integral of x^{.5} is x^{1.5}/1.5 NOT (x/1.5)^{1.5} so that, at x= 4, it is 4^{1.5}/1.5= 8/1.5= 16/3, NOT (4/1.5)^{1.5}= (8/3)^{1.5}.
By the way, it is a lot easier to put entire formulas in LaTeX, not just "bits and pieces".
Thanks once again.
Now I get about .55. This doesn't seem right, again.
The actual answer is 5/9, which is approximately .55.
When I graph the original two lines it seems to have a much larger area, but an answer is an answer. Thanks.
  • · Replies 18 ·
  • · Replies 44 ·
  • · Replies 105 ·
  • · Replies 25 ·
