Integration by partial fraction problem (∫dx/x(x^2 + 4)^2)
The integral ∫dx/x(x^2 + 4)^2 can be solved using partial fraction decomposition. The correct setup involves expressing the integrand as A/x + (Bx+C)/(x^2 + 4) + (Dx+E)/(x^2 + 4)^2. After proper expansion and solving for coefficients, the values are determined as A=1/16, B=-1/16, C=0, D=-1/4, and E=0. This method simplifies the integration process significantly.
  • Understanding of partial fraction decomposition
  • Familiarity with integration techniques
  • Knowledge of polynomial expressions and their manipulation
  • Basic algebra for solving equations
  • Study the method of partial fraction decomposition in detail
  • Learn about integration techniques for rational functions
  • Explore substitution methods in integration, such as u-substitution
  • Practice solving integrals involving higher powers of polynomials
Students studying calculus, particularly those focusing on integration techniques, as well as educators looking for examples of partial fraction decomposition in action.
Bimpo
I came across a problem that I can't solve
and it is ∫dx/x(x^2 + 4)^2
None
So I'm pretty sure this is to be solved by partial fraction since I am on a chapter on
Integration by partial fraction.
so I started with A/x + (Bx+C/x^2+4) + [Dx+E/(x^2 +4)^2]
and I get a reeeeaallllyy loooonnngg equation once I go around that
Am I on the right track? Or did I make a mistake? is this even to be solved by partial fraction?
First rewrite as \int\frac{1}{x(x^2 + 4)^2} dx
Then turn into partial fractions (lets ignore the integral part for now and focus on the fraction): \frac{A}{x} + \frac{B}{(x^2 + 4)^2} = \frac{1}{x(x^2 + 4)^2}
A (x^2 + 4)^2 + Bx = 1
Solve for A and B and plug back in.
None
First try the substitution u = x2 .
You will still get to work with partial fractions, but they won't be quite as complicated.
I assume your problem is actually \displaystyle \int\ \frac{dx}{x(x^2+4)^2}\,.
Parentheses are important.
You should have written A/x + (Bx+C)/(x^2+4) + (Dx+E)/(x^2+4)^2. As SammyS said, parentheses are important.
Your expansion is fine. If you stick with this approach, you should find A=1/16, B=-1/16, C=0, D=-1/4, and E=0.
sorry for late response but thanks for the replies
  • · Replies 16 ·
