How to Integrate \(\sqrt{1+u^2}\)?
  • Thread starter Thread starter flash
    Integration
To integrate \(\sqrt{1+u^2}\), hyperbolic substitution using \(u = \sinh(v)\) simplifies the process significantly, transforming the integral into a more manageable form. The integral can also be approached using a standard trigonometric substitution, such as \(u = \tan(x)\), although the hyperbolic method is often faster. The discussion highlights that both methods yield the same result, but familiarity with hyperbolic functions may be necessary for effective application. Additionally, a related integral involving the sinc function is raised, prompting inquiries about normalization. Understanding these techniques can enhance integration skills for complex functions.
flash
Hi
I am trying to integrate:
<br /> \sqrt{1+u^2}<br />
It looks simple but it's causing me a lot of problems. I've tried substitution, and by parts but can't get it. Thanks for any help!
You can try u=Sinh(v)\equiv\frac{e^{v}-e^{-v}}{2}
You thereby get:
\frac{du}{dv}=Cosh(v)\equiv\frac{e^{v}+e^{-v}}{2}\to{du}=\Cosh(v)dv
Since you may verify that the hyperbolic functions satisfy the identity Cosh^{2}(v)-Sinh^{2}(v)=1, your integral is readily transformed to:
\int\sqrt{1+u^{2}}du=\int\sqrt{1+Sinh^{2}(v)}Cosh(v)dv=\int{Cosh^{2}(v)}dv which is easily integrated.
Thanks. So I have to use hyperbolic functions to do it?
I just dug this up...do you think I could use it?
<br /> \int\sqrt{a^2+u^{2}}du=\frac{u}{2}\sqrt{a^2+u^2}+\frac{a^2}{2}ln |u + \sqrt{a^2+u^2}| <br />
Sure you can.
Yields the same result. :smile:
To see that it is the same, let's compute the integral with hyperbolic substitution:
I=\int{C}osh^{2}(v)dv=Sinh(v)Cosh(v)-\int{S}inh^{2}(v)dv=Sinh(v)Cosh(v)-\int(Cosh^{2}(v)-1)dv=
Sinh(v)Cosh(v)+v-\int{C}osh^{2}(v)dv=Sinh(v)Cosh(v)+v-I
That is, we have the expression:
I=Sinh(v)Cosh(v)+v-I
yielding:
I=\frac{1}{2}Sinh(v)Cosh(v)+\frac{1}{2}v
Now, we have v=Sinh^{-1}(u)
Using the identity:
Cosh^{2}(y)-Sinh^{2}(y)=1
we get Cosh(Sinh^{-1}(u))=\sqrt{1+u^{2}}
since we have, of course Sinh(Sinh^{-1}(u))=u
Thus, our first term may be rewritten as:
\frac{1}{2}Sinh(v)Cosh(v)=\frac{u}{2}\sqrt{1+u^{2}}
Using the exponential representation of the the hyperbolic sine, you should have little trouble representing the inverse function of hypsine in terms of the natural logarithm.
That constitutes the second term in the formula you found.
Awesome. Thanks heaps for your help! I should be right to do it now.
Basically there are 2 ways of doing this integral: A normal trig substitution, u= tan x, or the hyperbolic trig one arildno suggested. The hyperbolic one is faster, but unless you are familiar with hyperbolic trig functions it is harder to spot when to use them as a substitution. They used a more general substitution for the formula you gave: u= a tan x.
Does anyone know any tricks or how to integrate this function from negative inf to positive inf?
<br /> \int\\sinc( 2*pi*W*(t - k/(2*W)) ) * sinc( 2*pi*W*(t - j/(2*W)) )dt <br />
Thanks.
The normalized or unnormalized sinc function?
  • · Replies 105 ·
  • · Replies 22 ·
  • · Replies 44 ·
  • · Replies 27 ·
