Why Is Substitution Failing in Integrating This Function?
Substitution methods for integrating the function have been unsuccessful with various attempts, including using u-substitutions like u=√(16x-x^8) and u=x^4. The discussion suggests that the initial approaches were too complex and recommends a simpler substitution based on the expression √(x(16-x^7)). The correct method involves bringing something back from outside the square root, completing the square, and potentially using a trigonometric substitution. A promising substitution mentioned is u=x^(7/2)/4. The conversation emphasizes the importance of choosing the right u-sub for successful integration.
songoku
Find
$$\int \frac{x^3}{\sqrt{16x-x^8}}dx$$
u - substitution
trigonometry substitution
I tried using substitution ##u=\sqrt{16x-x^8}##, didn't work
Tried factorize ##x## from the denominator and then used ##u=\sqrt{16-x^7}##, didn't work
Tried using ##u=x^4## also didn't work
How to approach this question? Thanks
This was the right approach, but your u-sub is too fancy. Use a different u-sub from the expression ##\sqrt{x(16-x^7)}##.
It falls into place after that. In this problem you'll have to bring something back from outside the square root (which you'll see once you use the right U-sub), a complete the square, and a trig sub.
Thank you very much for the help romsofia
##u=\frac{x^{7/2}}{4}## looks promising
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 44 ·
  • · Replies 22 ·
  • · Replies 28 ·
  • · Replies 31 ·
  • · Replies 27 ·
