Integration of a gaussian function
8 replies · 5K views · last reply
JHans
Hey, all. I need help computing a particular integral that's come up in my quantum mechanics homework (Griffith 1.3 for anyone who's interested). It involves integration of a gaussian function:
[tex]\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {x}{e^{{-\lambda}{(x-a)^2}}} \, dx[/tex]
Where [tex]\lambda[/tex] and [tex]a[/tex] are positive real constants.
For the life of me I cannot figure out how to compute that integral... u-substitution doesn't seem to be an option, and integration by parts just makes things more confusing. Can someone please help me?
You could do it easily if you had
[tex]\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {(x-a)}{e^{{-\lambda}{(x-a)^2}}} \, dx[/tex]
right? Because then it would be a simple substitution. So write
[tex]\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {x}{e^{{-\lambda}{(x-a)^2}}} \, dx = \sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {(x-a)}{e^{{-\lambda}{(x-a)^2}}} \, dx + \sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {a}{e^{{-\lambda}{(x-a)^2}}} \, dx[/tex]
and think about how to do the second piece. It should look familiar.
I hadn't thought of that! That's a clever trick. Am I correct in thinking the second integral simplifies to:
[tex]{\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {a}{e^{{-\lambda}{(x-a)^2}}} \, dx}={a}[/tex]
And so the integral:
is simply the first integral you wrote down (solvable by u-substitution) + a?
How did you obtain a from that? I'm not saying that's wrong, but you need to show how you got it.
I'm sorry! Here's the process I went through:
[tex]{\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {a}{e^{{-\lambda}{(x-a)^2}}} \, dx}[/tex]
Because a is a constant, it can be taken out of the integral:
[tex]{{a}\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {e^{{-\lambda}{(x-a)^2}}} \, dx}[/tex]
Then I performed a u-substitution:
[tex]{u ={x-a}},{du = dx}[/tex]
[tex]{{a}\sqrt{\frac{\lambda}{\pi}}\int_{-\infty}^{+\infty} \! {e^{{-\lambda}{u^2}}} \, du}[/tex]
I then used a second u-substitution:
[tex]{v = {\sqrt{\lambda}u}}, {\frac{dv}{\sqrt{\lambda}} = du}[/tex]
[tex]{{a}\sqrt{\frac{1}{\pi}}\int_{-\infty}^{+\infty} \! {e^{{-\lambda}{v^2}}} \, dv}[/tex]
The integral is the well-known Gaussian integral:
[tex]{\int_{-\infty}^{+\infty} \! {e^{{-\lambda}{v^2}}} \, dv}={\sqrt{\pi}}[/tex]
And so I have:
[tex]{{a}{\sqrt{\frac{1}{\pi}}}\sqrt{\pi}}={a}[/tex]
Now I'm a bit confused, though... I came across an integral on Wikipedia's list of integrals for exponential functions, and they have this:
[tex]\int_{-\infty}^{\infty} \! {x}{e^{-a{(x-b)^2}}} \ dx={b\sqrt{\frac{\pi}{a}}}[/tex]
How does the integral we've broken into two parts become that?
Is anyone able to help? This is seriously stumping me.
You have already been given a complete solution, but it does require some final work on your part.RGV
I'm sorry, but I'm having difficulty "seeing" this complete solution and how to work it.
I understand what was said earlier, that:
[tex]{\sqrt{\frac{\lambda}{\pi}} \int_{-\infty}^{+\infty} \! {x}{e^{-\lambda{(x-a)^2}}} \ dx} = {\sqrt{\frac{\lambda}{\pi}} \int_{-\infty}^{+\infty} \! {(x-a)}{e^{-\lambda{(x-a)^2}}} \ dx} + {\sqrt{\frac{\lambda}{\pi}} \int_{-\infty}^{+\infty} \! {a}{e^{-\lambda{(x-a)^2}}} \ dx}[/tex]
It seems to me that the first integral is solvable by u-substitution:
[tex]{u=(x-a)}, {du=dx}[/tex]
[tex]{\sqrt{\frac{\lambda}{\pi}} \int_{-\infty}^{+\infty} \! {(x-a)}{e^{-\lambda{(x-a)^2}}} \ dx} = {\sqrt{\frac{\lambda}{\pi}} \int_{-\infty}^{+\infty} \! {u}{e^{-\lambda{u^2}}} \ dx}[/tex]
The antiderivative of that integral is:
[tex]\frac{-e^{-\lambda{u^2}}}{2\lambda}[/tex]
Evaluating that antiderivative at the limits of negative and positive infinity seems to yield 0.
Meanwhile, as I've shown about, the second integral can be solved by two round of u-substitution, yielding the constant a. Altogether, then:
[tex]{\sqrt{\frac{\lambda}{\pi}} \int_{-\infty}^{+\infty} \! {x}{e^{-\lambda{(x-a)^2}}} \ dx}=a[/tex]
However, that doesn't mesh with the definite integral identity I found online (shown in an earlier reply). Have I gone awry somewhere in my calculations, or is the identity I found incorrect?
EDIT: Nevermind... I realized that in examining the integral identity I found in an integral table, I'd been neglecting to apply the constant in front of the integral. Once I did that, it all clicked and became equivalent to the answer I derived (with help) above. Thank you all so much. I apologize for being a bit dense toward the end.
