Integrate 1/(1+e^x) dx: Solving the Problem
  • Thread starter Thread starter cloveryeah
    Integration
The integration of 1/(1+e^x) dx was approached with the substitution t=1+e^x, leading to an incorrect formulation of the integral as 1/(t^2-1). The correct substitution should yield dt=e^xdx=(t-1)dx, allowing for the integral to be expressed as 1/t * dt/(t-1). This method leads to the need for partial fraction decomposition to solve the integral accurately. The discussion emphasizes the importance of proper substitution in integration techniques.
cloveryeah
integrate 1/(1+e^x) dx
firstly i let t=1+e^x
and then i come to : integrate 1/(t^2-1)
and then i put t=secx
but then the final ans is -1/2 ln | 2/e^x +1 |
it should be 1 instead of 2, i hv checked for the steps for so many times, but found nothing wrong
You have done the substitution wrong.
If t= 1+ e^x then dt= e^xdx= (t- 1)dx so that \frac{1}{t- 1}= dx.
\int \frac{1}{1+ e^x}dx= \int \frac{1}{t} \frac{dt}{t- 1}= \int \frac{1}{t(t- 1)} dt
NOT \int \frac{1}{t^2- 1} dt
Perhaps you should multiply the top and bottom of the expression by ##e^{-x}## and see what happens when you substitute ##u = e^{-x}##.
then you can use partial fraction i.e. create (t)- (t-1) in the numerator
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 54 ·
14K
