Finding Area Between Cosine Curves [0, pi] Using Integration
  • Thread starter Thread starter char808
    Integration
To find the area between the curves y=4cos(x) and y=4cos(2x) over the interval [0, pi], the first step is to determine the points of intersection by solving the equation 4cos(x) = 4cos(2x). This leads to the equation 0 = cos(2x) - cos(x), which can be simplified using trigonometric identities. The identity cos(2x) = cos^2(x) - sin^2(x) can be particularly useful for rewriting the equation in a solvable form. Understanding these identities is crucial for successfully integrating and calculating the area between the curves. Mastery of trigonometric identities will facilitate solving similar problems in the future.
char808
Find the area between the curves y=4cosx and y = 4cos(2x) [0, pi]
I know I need to integrate this, but I get hung up finding the intersection of the two lines so I can split it into two different areas.
4cosx = 4 cos(2x)
0 = cos(2x) - cos(x) I think I need to use a trig identity here, but I'm not sure.
0 = sin(2x)sin(x)
x= pi?
4cosx = 4 cos(2x)
Finding the points of intersection would be a very good idea, and a trig identity would be very useful.
char808 said:
0 = sin(2x)sin(x)
?? How did you go from cos(2x) - cos(x) to sin(2x)sin(x)?
char808 said:
x= pi?
That looks like a guess.
Yes, I'm at a loss about where to go from here:
Possibility: (I am admittedly weak when it comes to trig, I could/can figure this out with almost any other function.)
0=cos(2x-x)
0= cos(x)
x= pi/2?
Yes indeed you do. What identities do you know for cos(2x)?
I don't. If you have a reference link I can go study I would appreciate that. Not covered in the book I have.
0=cos(2x-x)
cos(2x) - cos(x) \neq cos(2x - x)
char808 said:
0= cos(x)
x= pi/2
Did you study trig at any time? If so, what did you do with your book?
khanacademy.org has a lot of lectures about a variety of math stuff. You might start there.
Guessing also works. For example, cos(2x)=cos(x) means that, at one point, 2x=x (there are also other points, however). Only one point can satisfy 2x=x.
I last studied trig ~7-8 years ago. I probably sold the book.
I will check out the link.
hi char808 ! :smile:
you need to learn the standard trigonometric identities …
cosA - cosB = 2 sin((A+B)/2) sin((A-B)/2) would help :wink:
One that I found helpful was
cos(2x) = cos2(x) - sin2(x)
Two other forms of this are
cos(2x) = 2cos2(x) - 1
cos(2x) = 1 - 2sin2(x)
One of these can be used to write your equation cos(2x) = cos(x) as a quadratic in form.
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 105 ·
