Integration using Beta and Gamma Functions
200 replies · 36K views · last reply
Olok said:
I am assuming you don't derive these generation functions yourself?
So, where do you find these generating functions??
I saw it somewhere on the internet.
$$\sum_{n\geq 1} H^2_n x^n = \frac{\log^2(1-x)+\operatorname{Li}_2(x)}{1-x}$$
$$\sum_{n\geq 1} \frac{H^2_n x^{n+1}}{n+1} = \frac{-\log^3(1-x)}{3}+\int\frac{\operatorname{Li}_2(x)}{1-x} dx$$
The polylogarithmic integral of the RHS is extremely messy, what can be done?
No , it is not that difficult.
Note: It would be much better if you don't have that n+1 in the sum. To avoid it you first divide by x then integrate in the first step.
Hello,
It would be extremely hard to integrate.
$$\sum_{n=1}^{\infty}H_{n}^{2}x^{n} = \frac{\log^2(1-x) + Li_2(x)}{(1-x)}$$
$$\sum_{n=1}^{\infty}H_{n}^{2}x^{n-1} = \frac{\log^2(1-x) + Li_2(x)}{x(1-x)}$$
$$\sum_{n=1}^{\infty}\frac{H_{n}^{2}x^{n}}{n} = \int\frac{\log^2(1-x)}{x(1-x)} + \int \frac{Li_2(x)}{x(1-x)} $$
$$\int \frac{\log^2(1-x)}{x(1-x)} dx$$
Let $dv = \frac{\log^2(1-x)}{(1-x)} dx$
Let $u = \frac{1}{x} dx$
$$\int \frac{\log^2(1-x)}{x(1-x)} dx = \frac{-\log^3(1-x)}{3x} - \int \frac{\log^3(1-x)}{3x^2} dx$$
Let $t = 1/x \implies x = 1/t \implies dt = -1/x^2 \implies dx = -1/t^2 dt$
$$ = \log^3(t - 1) - \log^3(t)$$
$$ I = \int \frac{\log^2(1-x)}{x(1-x)} dx = \frac{-\log^3(1-x)}{3x} + \frac{1}{3}\int \frac{\log^3(-(t - t)) - \log^3(t)}{t^2} dt$$
Im lost trying to integrate..
Olok said:
Hello,
No no no. Try partial fractions not integration by parts.
I was tired yesterday, so I'll say that was my excuse for not realizing partial fractions...
$$\frac{\log^2(x) + Li_2(x)}{x(1-x)} = \frac{\log^2(x) + Li_2(x)}{x} - \frac{\log^2(x) + Li_2(x)}{(1-x)}$$
$$ \int \frac{\log^2(x) + Li_2(x)}{x(1-x)} = \frac{\log^3(x)}{3} + Li_3(x) - \int \frac{\log^2(x) + Li_2(x)}{(1-x)}$$
The integral is extremely difficult and lengthy (W|A) states.
So, what can be done?
That should be $\log^2(1-x)$ not $\log^2(x)$. I think we can have an antiderivative for $$\int \frac{\mathrm{Li}_2(x)}{1-x}$$
I really am tired...
$$\frac{\log^2(1-x) + Li_2(x)}{x} - \frac{\log^2(1-x) + Li_2(x)}{(1-x)}$$
The integral gives:
$$\int \frac{\log^2(1-x) + Li_2(x)}{x} - \frac{\log^2(1-x) + Li_2(x)}{(1-x)}dx = Li_3(x) + \int\frac{\log^2(1-x)}{x} dx +\frac{\log^3(1-x)}{3} - \int \frac{Li_2(x)}{1-x} dx$$
I checked WolframAlpha, we do have an antiderivative for the dilog but it is complicated, so I tried this:
$$-\log(x)\log(1-x) - Li_2(1-x) + \zeta(2) = Li_2(x)$$
We get:
$$\int \frac{Li_2(x)}{1-x} dx = (-)\int \frac{\log(x)\log(1-x)}{1-x}dx - Li_3(1-x) -\zeta(2)\log(1-x)$$
It is still complicated to integrate, but I think integration by parts is what we would do next.
That should be plus sign not minus between the two terms.
But it still doesn't help the integration process?
Sometimes a wrong sign can make your life miserable.
I like your humour.
By the way, I was wondering. Are you familiar with real analysis proofs? Because as I was cruising around, a lot of what you do here is based off of real analysis isn't it?
Can you perhaps link me to a page with all these generating functions? I mean, I tried searching online but got no results.
I did a lot of work on this. And this is what I have to now:
$$\sum_{n=1}^{\infty} \frac{H_{n}^{2}x^n}{n} = \log^2(1-x)\log(x) + 2Li_3(1-x) +2\zeta(2)\log(1-x) - \int \frac{Li_2(x)}{1-x} dx$$
The left over integral is very hard, but I am initially able to do this:
$$\int \frac{Li_2(x)}{1-x} dx = \Li_2(x)\log(1-x) - \int \frac{\log^2(1-x)}{x} dx$$
I remember you showed me a series a while ago, another gen. function.
I got:
$$2\sum_{n=1}^{\infty} \frac{x^{n+1}H_n}{(n+1)^2} = \int \frac{\log^2(1-x)}{x} dx$$
But the issue: How can I do the sum? The $x^{n+1}$ will cause a very big issue.
I took a course in real analysis a year ago. To justify all the steps we need a firm knowledge of real analysis which I think I don't have.
Well , it is difficult to find them. They are not collected in one paper but scattered in many places.
I am not sure how you got that ? Maybe you are messing something ?
I have a way of approaching this Ill post tomorrow, it is quite late here in Turkmenistan.
Anyway, have you actually solved this problem yourself?
No , we are solving it together. I just thought of it when you posted that problem.
Thats good. Collaboration for success.
For about two days I do not have time to work on this, since half my 11th grade semester is about to be over, and I am in a time crunch. Is it fine if we start working on this intensively in 2-3 days?
Thanks for cooperating!By the way:
http://mathhelpboards.com/calculus-10/integration-using-beta-gamma-functions-12437-9.htmlWe were using the wrong sum for the log^2 integral!
$$\sum_{n=1}^{\infty} \frac{x^k}{k} = -\log(1-x)$$
It doest equal $\frac{\log(1-x)}{x-1}$
Ok , no problem.
By the way:
I don't see what is wrong !
ZaidAlyafey said:
Ok , no problem.
OK,
I am ready to begin the problem again.
Just a question.
By any chance, do you have any other generating functions?
I don't see a way to use that one.
Olok said:
Just a question.
I found an interesting thread .
$$\sum_{n\geq 1} H^2_n x^{n-1} = \frac{\log^2(1-x)}{x}+\frac{\log^2(1-x)}{1-x}+\frac{\operatorname{Li}_2(x)}{1-x}+\frac{\operatorname{Li}_2(x)}{x}$$$$\sum_{n\geq 1} \frac{H^2_n}{n} x^{n} = \int^x_0\frac{\log^2(1-t)}{t}\,dt +\int^x_0\frac{\operatorname{Li}_2(t)}{1-t}\,dt-\frac{1}{3}\log^3(1-x)+\operatorname{Li}_3(x)$$
$$\int^x_0\frac{\operatorname{Li}_2(t)}{1-t}\,dt = -\log(1-x)\operatorname{Li}_2(x)-\int^x_0 \frac{\log^2(1-t)}{t}\,dt$$
Hence we get
$$\sum_{n\geq 1} \frac{H^2_n}{n} x^{n} = -\log(1-t)\operatorname{Li}_2(t)-\frac{1}{3}\log^3(1-x)+\operatorname{Li}_3(x)$$
$$\sum_{n\geq 1} \frac{H^2_n}{n} x^{n-1} = -\frac{\log(1-x)\operatorname{Li}_2(x)}{x}-\frac{1}{3}\frac{\log^3(1-x)}{x}+\frac{\operatorname{Li}_3(x)}{x}$$
$$\sum_{n\geq 1} \frac{H^2_n}{n^2} x^{n} =\frac{ \operatorname{Li}^2_2(x)}{2}-\frac{1}{3}\int^x_0\frac{\log^3(1-t)}{t}\,dt+\operatorname{Li}_4(x)$$
$$\frac{1}{3}\int^x_0\frac{\log^3(1-t)}{t}\,dt =\operatorname{Li}_4(x)+\frac{ \operatorname{Li}^2_2(x)}{2}-\sum_{n\geq 1} \frac{H^2_n}{n^2} x^{n} $$
Hence we get
This is good, but we still cannot do our integral. Here we don't have $\log^3(t)$ as a factor.
$$\int^x_0\frac{\log^3(1-t)}{t}\,dt =3\operatorname{Li}_4(x)+\frac{3}{2}\operatorname{Li}^2_2(x)-3\sum_{n\geq 1} \frac{H^2_n}{n^2} x^{n} $$
$$\int^1_0 \frac{\log^3(1-x)\log^3(x)}{x}\,dx$$
Integration by parts
$$\int^1_0 \frac{\log^3(1-x)\log^3(x)}{x}\,dx = 9\int^1_0 \frac{\operatorname{Li}_4(x)\log^2(x)}{x}\,dx+\frac{9}{2}\int^1_0 \frac{\operatorname{Li}^2_2(x)\log^2(x)}{x}\,dx-9\sum_{n\geq 1} \frac{H^2_n}{n^2} \int^1_0x^{n-1}\log^2(x)\,dx $$
$$\int^1_0 \frac{\log^3(1-x)\log^3(x)}{x}\,dx = 9\int^1_0 \frac{\operatorname{Li}_4(x)\log^2(x)}{x}\,dx+\frac{9}{2}\int^1_0 \frac{\operatorname{Li}^2_2(x)\log^2(x)}{x}\,dx-18\sum_{n\geq 1} \frac{H^2_n}{n^5} $$
The first integral
$$\int^1_0 \frac{\operatorname{Li}_4(x)\log^2(x)}{x}\,dx = 2\zeta(7)$$
I still have to think of a way to solve
$$\int^1_0 \frac{\operatorname{Li}^2_2(x)\log^2(x)}{x}\,dx$$
The first integral
Lets actually pass on this integral, I have a different contour integration question, which may or may not help with this later on.
Anyway, I hope Ill catch you there!
Here is the evaluation of the last integral. There might be a mistake in a constant
$$\int^1_0 \frac{\operatorname{Li}^2_2(x)\log^2(x)}{x}\,dx = \sum_{n,k\geq 1}\frac{1}{(nk)^2}\int^1_0x^{n+k-1}\log^2(x)\,dx= 2\sum_{n,k\geq 1}\frac{1}{(nk)^2(n+k)^3}$$
$$\sum_{n,k\geq 1}\frac{1}{n^2k^2(n+k)^3} = \sum_{n,k\geq 1}\frac{n+k-k}{n^3k^2(n+k)^3} = \sum_{n,k\geq 1}\frac{1}{n^3k^2(n+k)^2}-\sum_{n,k\geq 1}\frac{1}{n^3k(n+k)^3}$$
First sum
$$\begin{align}\sum_{n,k\geq 1}\frac{1}{n^3k^2(n+k)^2} &= \sum_{n,k\geq 1}\frac{1}{n^4k^2(n+k)}-\sum_{n,k\geq 1}\frac{1}{n^4k(n+k)^2}\\
&=\sum_{n,k\geq 1}\frac{1}{n^5k^2}-\sum_{n,k\geq 1}\frac{1}{n^5k(n+k)}-\sum_{n,k\geq 1}\frac{1}{n^5k(n+k)}+\sum_{n,k\geq 1}\frac{1}{n^5(n+k)^2}\\
&=\zeta(5)\zeta(2)-2\sum_{n \geq 1}\frac{H_n}{n^5}+\sum_{n \geq 1}\frac{H^{(2)}_n}{n^5}
\end{align}$$
$$\begin{align}\sum_{n,k\geq 1}\frac{1}{n^3k(n+k)^3} &= \sum_{n,k\geq 1}\frac{1}{n^4k(n+k)^2}-\sum_{n \geq 1}\frac{H_n^{(3)}}{n^4}\\
&= \sum_{n,k\geq 1}\frac{H^{(2)}_n}{n^5}-\sum_{n,k\geq 1}\frac{H_n}{n^5}-\sum_{n \geq 1}\frac{H_n^{(3)}}{n^4}
\end{align}$$
