Integration using inverse trig indentities?
The discussion focuses on two integrals involving inverse trigonometric identities. For the first integral, participants suggest using the substitution u = cos(x) to simplify the expression, noting that a second substitution may not be necessary. The second integral requires completing the square in the denominator for easier integration. Attempts at u-substitution for the first integral yielded incorrect results, highlighting the complexity of the problem. Overall, the conversation emphasizes strategic substitutions and algebraic manipulation to solve the integrals effectively.
Cpt Qwark
1.\int{\frac{sinx}{1+cos^{2}x}} \, dx
2.\int{\frac{1}{13-4x+x^2}} \, dx
Inverse trig identities.
For the first one, I'm not too sure about what to do with the sinx on the numerator and i have tried u-substitution to no avail (different answer). For the second one, I tried factorising but only had solutions for x\inℂ.
You can maybe try to start with the substitution u = cos(x) and reforming the integral. A second substitution will be necessary after the first substitution.
Second substitution is not necessary. It can be done in that first one.
For the second integral start by completing the square in the denominator.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 22 ·
