Interacting QFT - construction of states
paweld
Let's consider self-interacting scalar field described by action:
<br /> S = \int d^4 x \frac{1}{2} \left[ \partial_\mu \phi \partial^\mu \phi - m^2 \phi^2 - \frac{\lambda}{4!}\phi^4\right]<br />
Using relation between Poisson bracket in classical mechanics and
comutators of quantum operators we have:
<br /> [\partial_0\hat{\phi}(t,x_1),\hat{\phi}(t,x_2)] = - i \delta(x_1-x_2)<br />
Unfortunatelly in case of interacting field we cannot decompose field in terms
of basic solution (modes) and we don't have operators which create and anihilate
modes. So in case of interaction field construction of Hilbert space on which
\hat{\phi} acts in not straightforward. What is the Hilbert space
on which field operator acts and how the action of it on some basic states
looks like.
Some people claim that in case of interaction we have to assume that the spectrum
of full hamiltonian is the same as spectrum of hamiltonian without interaction
(so that the theory poses particle interpretation). However even if this assumption
is correct we still don't know how \hat{\phi} on these states, and whole
theory is underdetermined.
Just because you don't know how \hat\phi act on interacting states doesn't mean your whole theory is undermined.
Here is one possible solution to your dilemma:
You can still use the normal mode decomposition of the scalar field,
\hat\phi(x)=\int\frac{d^3\mathbf{p}}{(2\pi)^3}\frac{1}{\sqrt{2\omega_{\mathbf{p}}}} (\hat{a}_{\mathbf{p}}e^{-ipx}+\hat{a}^\dag_{\mathbf{p}}e^{ipx}),​
but now, the single-particle states are no longer created by \hat{a}^\dag_\textbf{p}. Instead, the physical, one particle state in the presence of interactions may be written in terms of Fock states as follows
|\mathbf{p}\rangle = c_0 a^\dag_{\mathbf{p}}|0\rangle + c_1 a^\dag_{\mathbf{p}/2} a^\dag_{\mathbf{p}/2}|0\rangle + \ldots​
where there are an infinity of terms in the Fock expansion and the coefficients are, in principle, calculable in field theory. Note that you know how \hat{\phi} acts on each term individually. Your problem should be solved.
Thanks for answer. I'm afraid that your decomposition of \phi does not fulfill
the Euler-Lagrange equation derived form my action:
<br /> \square \phi + m^2 \phi = \frac{\lambda}{3!}\phi^3<br />
(or probably the momentum in exponens is not on shell).
The decomposition of state in terms of Fock states looks interesting.
It means that the state of momentum p in case of interacting theory
needs to be a superposition of multiparticles states.
looks like.
In 4-dimensional space-time, this is one of the unsolved problems. In lower dimensions it is solved bot the answer cannot be explained in few words. For 2 dimensions, see, e.g.,
James Glimm and Arthur Jaffe
The λ(φ4)2 quantum field theory without cutoffs III
Acta Mathematica 125, 1970, 203-267
http://www.springerlink.com/content/t044kq0072712664/
Ok, I made a slight typo: the mode expansion should have been in the Schrodinger picture (not the Heisenberg as I have written it)
<br /> \hat\phi(\mathbf{x})=\int\frac{d^3\mathbf{p}}{(2\pi)^3}\frac{1}{\sqrt{2\omega_{\mathbf{p}}}} (\hat{a}_{\mathbf{p}}e^{i\mathbf{p}\mathbf{x}}+\hat{a}^\dag_{\mathbf{p}}e^{-i\mathbf{p}\mathbf{x}})<br />
The time evolution of the field operator will in general be complicated -- again, this necessitates an expansion similar to the one I described for the physical particle.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
