Interested in average household energy consumption in 2011
  • Thread starter Thread starter IntegrateMe
    Average Energy
In 2011, average household energy consumption figures were not readily available, but data from the 2009 Residential Energy Consumption Survey indicated that U.S. households used an average of 95 million British thermal units (Btu) per year, a significant decrease from 138 million Btu in 1978. Energy consumption patterns have evolved, with larger homes, fewer occupants, and improved energy efficiency contributing to this decline. The discussion highlights that coal and DTE products are likely significant fuel sources in residential settings. Additionally, there is a need to clarify whether the reported energy figures account for primary energy or just in-home usage. Overall, the conversation emphasizes the importance of understanding household energy consumption trends over time.
IntegrateMe
Particularly, what do the figures look like for the amount of energy consumed per household in 2011? As a comparison, how much energy have you consumed in 2011?
Also, I'm interested to know what kind of fuels or carriers are most often used. I'm tempted to believe that coal is probably one of the bigger fuel supplies and DTE products are more readily installed in consumers' homes.
Thanks for any insight you guys can provide, looking forward to reading some interesting posts.
I think it is too soon to have any 2011 data. How's this for 2009:
First results from EIA's 2009 Residential Energy Consumption Survey (RECS)
The 2009 RECS collected home energy characteristics data from over 12,000 U.S. households. This report highlights findings from the survey, with details presented in the Household Energy Characteristics tables.
How we use energy in our homes has changed substantially over the past three decades. Over this period U.S. homes on average have become larger, have fewer occupants, and are more energy-efficient. In 2005, energy use per household was 95 million British thermal units (Btu) of energy compared with 138 million Btu per household in 1978, a drop of 31 percent.
from US EIA
http://38.96.246.204/consumption/residential/reports/2009overview.cfm
I have not read it so I don't know how they came up with the numbers or what they mean. 95E6 Btu per year is equal to about 3.2 kW; or 75 kW-hr/day. This is clearly more than just electric usage which is closer to 1 kW per household.
edit - plus you need to consider whether this is energy use in the home or 'primary' energy - that is, does it include conversion efficiencies (heat rate of the power plant for example).
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
11K
