Understanding Interference of Sound Experiment
The experiment involves a speaker mounted without casing, with two microphones positioned above and below it, both connected to a CRO to display waveforms. The observed destructive interference occurs because the sound waves radiating from the back of the speaker are 180 degrees out of phase with those from the front, affecting the signals received by the microphones. Mounting the speaker on a baffle helps prevent this destructive interference by minimizing the backward sound waves that can reflect and interfere with the forward waves. The baffle also enhances sound quality by improving the speaker's radiation resistance. Understanding these principles clarifies why the setup leads to phase cancellation and the importance of speaker mounting.
Jimmy87
Can someone please help explain an experiment which I am struggling to understand. You have a speaker without any of the outer casing (just the small disk part) and secure it onto a clamp stand. You then have two microphones; one above the speaker and one below it which are both the same distance from the speaker. The microphones are connected to a CRO which display both waveform at the same time. You drive the speaker with an signal generator at 500Hz. Both the waveforms on the CRO destructively interfere perfectly on the screen. This is what I don't understand. Doesn't sound radiate in all directions from the source so therefore shouldn't the sound reach each microphone in the same phase seeming as though they are located the same distance from the speaker?
The other thing I don't quite get is that this experiment is suppose to show why you need to mount a speaker onto a board (baffle). Mounting it onto a board cuts out the sound going backwards out of the speaker that would normally destructively interfere. Why does it normally interfere? How can the sound that is going backwards interfere with the sound that is going forwards?
Many thanks in advance for any help!
Science news on Phys.org
If the microphones are the same distance away from the speaker, they are indeed receiving the signals with the same phase. If you display each microphone waveform separately as 2 traces on the oscilloscope, you will see identical sine waveforms. You must be using an "A-B" feature of the o'scope, if you are seeing a single flat trace.
The speaker enclosure is more meant to enhance the sound of the speaker, by resonating at certain frequencies. It also can help prevent desctructive interference if the backward moving sound wave reflects off of a wall and becomes a forward moving sound wave. Depending on the distance to the reflecting wall, you could get partial cancellation of the total forward moving sound wave.
The OP's description of the experiment is a bit ambiguous. Since the mikes are "above" and "below" the speaker, I guess the speaker was pointing vertically not horizontally?
The sound wave radiated from the back of the speaker is 180 degrees out of phase with the sound radiated from the front. And of course if you rotate the microphone through 180 degrees, you also change the phase of the electrical signal by 180 degrees! So the result would be different it both mikes were pointing in the same direction, or if they were both pointing towards the speaker (i.e. the mike above was pointing down and the mike below was pointing up).
So there are plenty of reason why you might get phase cancellation, but without a more precise description of the experiment we don't know the actual reason in your experiment.
Oh, good point! I missed that interpretation. Thanks :smile:
I always understood that a baffle acts as a matching device. The comparatively small cone has comparatively large amplitude oscillations and the radiation resistance approaches zero where the cone is substantially smaller then the wavelength. See this Hyperphysics link.. (Just like a radio antenna.)
Using a baffle has the effect of increasing the radius of the speaker cone and raising the radiation resistance - improving the match. You could look upon it as simply disturbing more air around the drive unit.
This is not to disagree with the interference-based argument but the impedance based approach translates nicely to explaining the action of speaker cavities.
The measurement with the microphone in the OP doesn't necessarily depend upon the microphone directivity as small (probe) microphones work largely on the local pressure and are pretty much omnidirectional. This is unlike an RF antenna, which cannot be isotropic.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
