Internal and center of mass energies
12 replies · 8K views
negation
An object with kinetic energy K explodes into two pieces, each of which moves with twice the speed of the original object.
Compare the internal and center-of-mass energies after the explosion.
Let K1 be the kinetic energy of the main object before the explosion. k2 and k3 be the kinetic energies after explosion.
K1 = k2 + k3
Let K1 = 0.5m1v12 = K
Then
0.5m1v12 = 0.5m2v22 + 0.5m3v32
and since each pieces has twice the velocity of the original piece befor explosion
0.5m1v2 = 0.5m2(2v)2 + 0.5m3(2v)2
∴ 0.5m1v2 = 0.5(4v2)(m2+m3)
K1 = k2 + k3
Then
I am not following what you are doing. You seem to be equating the original kinetic energy to the sum of the final kinetic energies of the two parts? Why would k1 = k2 + k3?
Think of the problem this way: In the frame of reference of the centre of mass does the body have any energy before the explosion? How about after?
AM
AM
I equate them because the total energy is the sum of the KE of each particle.
However, I may be wrong.
I think it's good to ask what internal kinetic energy is and what center of mass kinetic enegry is and why kint + kcm = Ktotal
AM
What's the definition of the frame of reference of the center of mass?
The problem asks the center-of-mass energy and the internal energy after the explosion. I do not see any of them in your post.
I see, you assumed conservation of energy. It is not true in an explosion.
ehild
ehild
Where can we go from here?
Ktotal = [itex]\sum[/itex]0.5mivcm2 + [itex]\sum[/itex]0.5mivirel2 + [itex]\sum[/itex]mivirelvcm
Edit: why is a particle relative velocity to COM zero?
kint = 0.5m1vcm = m1vcm2
there are 2 pieces so 2m1vcm^2
kint/kcm = 4 but the answer is 3.
I spent 4 hrs on this. It's not going anywhere and very agonizing/
The CoM will travel with the same velocity as before the explosion, as the forces are internal. So the center-of mass KE is the same as the initial KE:
KECoM=1/2 m1v12
If m2 and m3 are the masses after the explosion, and m2+m3=m1, the total KE is
KE(total)=1/2 (m2v12+m3v32=2v12m1
The internal energy is the difference between the total energy and the energy of the translation of the CoM:
KE(internal)= KE(total)-KE(CoM)
So what is the ratio KEi/KE(CoM)?
ehild
KECoM=1/2 m1v12
ehild
I have managed to solve it by drawing it out and using geometry. However, one question persist when I attempt to derive K= Kint + Kcm.
Why is [itex]\sum[/itex] mivirel2 = 0?
Are vi rel the relative velocities with respect to the CoM? How did you get that ∑ mivirel2 = 0? It is certainly wrong. What are the relative velocities? The pieces move in opposite directions, and have different masses. The velocity of one piece is v2=2v1, its relative velocity with respect to the CoM is v2rel=v1.
The other piece has velocity v3=-2v1. Its relative velocity is -2v1-v1=-3v1.
ehild
ehild said:
Are vi rel the relative velocities with respect to the CoM? How did you get that ∑ mivirel2 = 0? What are the relative velocities? ehild
Yes
My initial premise is
K = [itex]\sum[/itex]0.5 mivi2
but vi = (vcm + virel) (it would be great if someone can give me an intuitive sense of why vi = (vcm + virel)
then we have K = [itex]\sum[/itex]0.5mi(virel+vcm).(vcm+virel)
= [itex]\sum[/itex]0.5mivcm2 + [itex]\sum[/itex]mivcm . virel2 + [itex]\sum[/itex] mivirel2
and then the book states [itex]\sum[/itex]mivcm.virel = 0 because virel = 0 since it is the particle's velocity relative to the COM.
Unsure what this means.
negation said:
Yes
then we have K = [itex]\sum[/itex]0.5mi(virel+vcm).(vcm+virel)= [itex]\sum[/itex]0.5mivcm2 + [itex]\sum[/itex]mivcm . virel2 + [itex]\sum[/itex] mivirel2
I edited my previous post, read it.
Your formula is wrong. There is no square in the second term.
Recall how the CoM is defined.
The velocity of the CoM is VCoM=(∑mivi)/∑mi.
Virel=Vi-VCoM. Virel is not zero, but ∑miVirel=0
ehild
ehild
The square was a typo. It's hard to see what is going on with all the brackets when using tex.
