Do AC generators make use of interpoles?
  • Thread starter Thread starter Jacob Anderson
    Ac Generators
AC generators do not utilize interpoles since they lack a commutator, making neutral plane shift irrelevant. The armature reaction in alternators contributes to their synchronous impedance. Commutation can offer benefits in adjustable output voltage and direction when brushes are on a rotating assembly, potentially useful in applications like diesel-electric locomotives. Aligning all poles in the same orientation may reduce available flux but could also impact performance. For Halbach arrays, aligning magnets transaxially is preferred to ensure uniform crossing of magnetic field lines.
Jacob Anderson
Hello, new member here. I'm giving myself a crash course and can't find a direct answer to my query outright, so here I am:
Do A.C. generators make use of interpoles? I understand the concept of interpoles in D.C. machines, offsetting neutral plane shift; however, if we have, say, a brushless ac generator that has an external prime mover and uses permanent magnets in lieu of excitation windings, are we even worried about neutral plane shift? If it's a 3-phase machine my gut says no, but again it's a self-inflicted crash course... Any help would be greatly appreciated!
Your intuition is correct. Without a commutator shift of magnetic field is of no consequence.
Armature reaction in alternators is what's behind their "Synchronous Impedance" .
old jim
HUZZAH, thank you. That's been driving me crazy all day.
Whilst we're here, is there any particular benefit of commutation over rectification?
Also, going with the pmac concept, would aligning all the poles in the same orientation have a negative effect other than reducing the available flux? Alas, at least for now, my final question: were one to arrange said magnets in halbach arrays, would they need to be aligned with the magnetic fields aligned axially or transaxially? That question is more for clarification, I'm leaning greatly towards transaxial so the coils cross the field lines more uniformly.
The only benefit for commutation would be if the brushes were on a rotating assembly , then you could change the output voltage and even direction by rotating the brush assembly, this would also change the emf constant and torque constant, so it would function like a variable gear ratio. Might be useful for a primitive diesel electric locomotive, where the primer mover was constant speed.?? I think the Ward Lenard set achieved this effect and dominated the variable DC motor control industry from 1900 on Ward Lenard Control
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
10K
10K
