Interpretation of kinetic energy
The discussion revolves around the interpretation of kinetic energy (KE) as presented in Sears & Zemansky's University Physics. Two interpretations are highlighted: KE as the work done to accelerate a particle from rest and as the work a particle can perform when brought to rest. A scenario involving a ball compressing a spring illustrates the concept, emphasizing that the work done by the ball on the spring and vice versa are equal and opposite, reflecting conservation of mechanical energy. The conversation further explores how these works relate to the conservation of energy, suggesting that both the ball and spring must be considered as a system to understand the energy transformations involved. The discussion concludes with a request for clarification on how the cancellation of works demonstrates energy conservation.
Soren4
While studying energy on Sears & Zemansky's University Physics, I came up with a doubt on the meaning of kinetic energy. The book gives two possible physical interpretations of this quantity.
So the kinetic energy of a particle is equal to the total work that was done to accelerate it from rest to its present speed [...] The kinetic energy of a particle is equal to the total work that particle can do in the process of being brought to rest.
I'm okay with the first meaning of KE but I don't understand completely the second one. I don't understand how the particle can do work just because it owns KE.
Consider a ball with velocity ##v## that meets a spring, the spring is compressed and the ball is stopped. Following the previous interpretation of the kinetic energy, the ball should do work on the spring because of its KE. But does this really happen?
In the collision with the spring exerts a force ##f## on the ball and the ball exerts a force ##-f## on the spring. Are the two works done by the two forces equal and opposite?
Hello Soren,
Yes. That is conservation of mechanical energy. Sum of energies before and after is the same, so the changes add up to zero.
If you wait a little longer, the spring is compressed as far as it will go and the ball is at resst (has lost its kinetic energy). Then the spring pushes the ball away -- doing work on the ball that picks up kinetic energy again.
Likes Soren4
Yes, the spring is compressed.
Yes. The work of the spring on the ball is negative and the work of the ball on the spring positive with the same magnitude. This is just conservation of energy.
The two definitions are completely equivalent.
Likes Soren4
Thanks a lot for the replies @BvU and @Orodruin ! I hope that what I will ask makes sense: how does the "canceling out" of the works imply the conservation of energy, explicitly?
Firstly, to introduce the elastic potential energy ##U## it is necessary to take as "system" both the spring and the ball. Then is it possible to write the following? ##K_{initial, ball}-W_{spring}+W_{ball}=U_{system}##
Again, I don't know if it makes sense, but I would like to see in what way do the two works cancel out
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
