Intersections of axes and affine space
  • Thread starter Thread starter jostpuur
    Axes Space
jostpuur
Let natural numbers N,M be fixed such that 1\leq M < N. If x\in\mathbb{R}^N is some vector, and V\subset\mathbb{R}^N be some subspace with \textrm{dim}(V)=M. How likely is it, that x+V intersects the axes \langle e_1\rangle,\ldots, \langle e_N\rangle somewhere outside the origin?
I mean that x+V intersects the axis \langle e_n\rangle iff there exists \alpha\in\mathbb{R} such that \alpha e_n\in x + V and \alpha \neq 0.
By "likely" I mean that for example if x is a sample point of some random vector, and if V is spanned by some M sample vectors, and if the random vectors in question can be described by non-zero probability densities, then what is the probability for intersections of x+V and \langle e_n\rangle to exist?
Example M=1, N=2. If we draw a random line on the plane, chances are that the line will intersect both axes. The outcome that line intersects only one axis, is a special case, which can occur with zero probability.
Example M=2, N=3. If we draw a random plane into three dimensional space, chances are that the plane will intersect all three axes. The plane can also intersect only two or one axes, but these are special cases, which can occur with zero probability.
Example M=1, N=3. If we draw a random line into three dimensional space, changes are that the line will miss all three axes. The line can intersect one or two axes, but these outcomes occur with zero probability. The outcome that the line would intersect all three axes is impossible.
Looks complicated! I don't see a pattern here. What happens when N>3?
Before you can ask any question about a "random vector" you will have to specify what that means- in particular what probability distribution the "random" vector will satisfy.
I was unable to prove this but I figured out sufficient rough reasoning, that convinced me, that the answer is this: If M=N-1, the affine subspace will intersect all axes with probability 1, and if M<N-1, the affine subspace will miss all axes with probability 1.
HallsofIvy's comment is not on right track. The probability densities don't need to be defined with a greater precision than what I already did. Look at the three low dimensional examples for example. It should be clear that the stuff works out like I said.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
I asked online questions about Proposition 2.1.1: The answer I got is the following: I have some questions about the answer I got. When the person answering says: ##1.## Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##? But I don't understand what the author meant for the rest of the sentence in mathematical notation: ##2.## In the next statement where the author says: How is ##A\to...
