Engineering Intro EE - Voltage Divider Design circuit
The discussion focuses on designing a voltage divider circuit using specific resistor values. The primary equations utilized include the voltage output ratio and Thevenin resistance, with constraints set for R_th between 10 and 30. Initial calculations for R_1 yielded values of 56k, 68k, and 82k, leading to corresponding R_2 values of 14k, 17k, and 20k. A correction was noted regarding the resistance range, clarifying that R_th should actually be between 10,000 and 30,000 ohms. The conversation emphasizes the importance of considering all available resistor values in the E12 series for accurate results.
krtica
The link is an image with the question and circuit representation:
http://i49.tinypic.com/2mmwg8l.png
Here are the equations I used:
V_out/V_in = R_2/(R_1 + R_2) {using the node method}
R_thevenin (R_th) = R_2*R_1/(R_1+R_2)
And given the conditions =>
10 < R_th < 30
Manipulating this inequality I found that 50 < R_1 < 150, which left me with three possible values for R_1 (56, 68, 82).
Using the first equation, I put in the numbers, which gave me 0.2=R_2/(R_2+56) and solved for R_2 with every value I put in for R_1 (56, 68, 82).
R_2 values were 14, 17, and 20, respectively, which came to equate to 15, 18, and 22 when compared to the original set of resistors and the 10% condition.
I tried putting in the values of these resistors I used, because all gave me the right ratio of voltages, but they're incorrect.
Pardon how nuanced I may seem, it's been too long since I've done any physics..
I think you are on the right track.
10 < R_th < 30
This should be, 10,000 ≤ R_th ≤ 30,000
Aren't you missing some candidates here?
R₁ ∈ {56k,68k,82k,100k,120k,150k}
Wouldn't it just be the three since your given all the resistances available in the set E12?
120kΩ = 12 x 104
Right! Thanks.
  • · Replies 29 ·
