A Intro to String Theory: Lightcone Gauge & Oscillators
binbagsss
Lightcone gauge is ##X^u=\tau=1/\sqrt{2}(X^0+X^{D-1})## (1)
The mode expansions are:
My book says 'it is possible to solve for one of the oscillators in terms of all the others' with this relation.
What is a oscillator? Is this any of the ##X^{D}## coordinates, what exactly does ##n## represent, 'frequencies' of a given oscillator?
Does the notation ## X^{D-1}## refer to any spatial coordinate that is the preferred choice?
So basically the relation (1) reduces the number of equations to solve by one, is this what this statement means?
I think X0 is the infinite momentum direction i.e. the direction in which the string is travelling. XD-1 are the dimensions perpendicular to X0, the -1 is to remove the time dimension. Each string comprises a number of mass points which are described as harmonic oscillators, n is the number of the oscillator in the string.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
