MHB Is f(x) Its Own Inverse for Any Value of a?
The function f(x) = a + 4/(x-a) has been analyzed for its inverse properties. The derived inverse function f-1(x) = (a^2 - ax - 4)/(a - x) is deemed incorrect by some participants. Discussions revolve around whether f(x) is its own inverse for various values of a, with claims that it may only hold true for specific conditions. The consensus suggests that the function is not its own inverse universally. The investigation highlights the complexity of determining inverse relationships in this context.
bcasted
f(x)=a+4/(x-a)
f-1(x)=(a^2-ax-4)/(a-x)
Which of the following is true?
The function is the opposite of its own inverse for any value of a.
The function is its own inverse for positive values of a only.
The function is the reciprocal of its own inverse for positive values of a only.
The function is its own inverse for negative values of a only.
The function is its own inverse for any value of a.
Mathematics news on Phys.org
Re: Inverse functions problem help please
What has your investigation led you to find?
bcasted said:
f(x)=a+4/(x-a)
If this equation: $$f^{-1}(x)=\frac{a^2-ax-4}{a-x}$$
is meant to be the equation of the reverse function then this equation is false.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
