Understanding Inverse Trig Notations: Clarifying tan-1x and tan-2x
  • Thread starter Thread starter Rose Garden
    Inverse Trig
The notation tan-1x is commonly interpreted as arctan(x), while tan-2x is often seen as cot^2(x). There is a consensus that the notation tan-2x can lead to confusion and should be reconsidered to prevent misinterpretation as an inverse function. Context plays a crucial role in determining the meaning of these notations, with tan^n(x) typically indicating (tan x)^n, except for n=-1, which denotes arctan. The discussion highlights the need for clearer notation in mathematical contexts to avoid ambiguity.
Rose Garden
I just want to know, what tan-1x means to you guys? does it mean arctan or cot?
What about tan-2x? Isn't that cot2x? Shouldn't the notation tan-2x be banned to avoid misinterpreting it as an inverse trig function?
Mathematics news on Phys.org
tan-1(x) means arctan to me. But it's a very unfortunate notation. That's why I always use arctan atan or bgtan instead of tan-1...
It's indeed an unfortunate notation. However, LaTeX language has the function \arctan but I couldn'f find one for <arccotangent>, even though \cot exists. Unfortunately, the very friendly Mathematica software uses the misleading notation.
http://www.wolframalpha.com/input/?i=Integrate+1/(1+x^2)+
And the inverse hyperbolic functions are not defined in LaTeX, apparently.
Hi Rose Garden. Yes I would interpret \tan^{-1}x as arctan(x), while I would interpret \tan^{-2}x as \cot^2x.
In most cases hopefully the context would make it clear what function one was using, but in general I'd say that you should interpret \tan^{n}x as (\tan \, x)^n for all values of n except n=-1 which should be treated as arctan (and similar applies to the other trig functions).
BTW. If ever you wish to use the "-1" notation to mean reciprocal with a trig function just use the bracketed notation as for example :
{\rm cosec} \, x = (\sin x)^{-1}
As is usually the case, context means a lot. When you're dealing with a variable, x-1 means the reciprocal of x, of 1/x.
When you're dealing with functions, however, an exponent of -1 usually means the inverse of the function. So tan-1(x) means arctan(x), not 1/tan(x).
thanks guys I think I'm getting the picture now
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
