Inverse Variation: Solve for y when x=5
  • Thread starter Thread starter amanda_
    Inverse Variation
To find y when x = 5, given that y varies inversely as the square of x and y = 1/8 when x = 1, the correct equation is y = k/x². The constant k can be determined by substituting the known values, resulting in k = 1/8 when x = 1. After calculating k, substituting x = 5 into the equation yields y = 1/8 * (1/5²), which simplifies to y = 8/25. The initial confusion arose from misapplying the inverse variation formula. The correct answer for y when x = 5 is 8/25.
amanda_
If y varies inversely as the square of x, and y = 1/8 when x = 1, find y when x = 5.
y = 8/25
y = 1/200
The equation to find this is y=k/x, I know that. I've tried to plug in both given answers to see which ones matched but neither of them did. I'm not sure what to plug in for k or x. I just need someone to correctly set this up for me and I'll be able to solve it.
y = 8/25
y = 1/200
No, it says that y varies inversely as the square of x.
The equation to find this is y=k/x[/QUOTE]
You'll need to try again, if the cube of x is x3, the square of x is?
x2
So if I square 5 and cross multiply it's 8/25. Is that right?
amanda_ said:
x2
No, it's not. You skipped some steps. First, what is the equation? And you know that when x = 1, y = 1/8.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
