Invertible Matrices (Ring) - How to Show Existence of Inverse in Zp
  • Thread starter Thread starter Justabeginner
    Matrices Ring
The discussion focuses on the invertibility of 2x2 matrices over the finite field Zp, where p is a prime number. It establishes that a matrix of the form (a b c d) is invertible if its determinant, calculated as ad - bc, is non-zero. The participants confirm that in Zp, every non-zero element has an inverse, which is not the case in Z_n when n is not prime. The existence of an inverse matrix is demonstrated through the formula B = [1/(ad-bc)](d -b -c a), highlighting the significance of prime numbers in determining the properties of the matrix.
  • Understanding of matrix theory, specifically 2x2 matrices.
  • Knowledge of determinants and their role in matrix invertibility.
  • Familiarity with finite fields, particularly Zp, where p is a prime.
  • Basic algebraic properties of fields, including closure and existence of inverses.
  • Study the properties of determinants in matrix algebra.
  • Learn about finite fields and their applications in linear algebra.
  • Explore the implications of prime numbers in modular arithmetic.
  • Investigate the relationship between matrix invertibility and field properties in greater depth.
Mathematicians, students of linear algebra, and anyone interested in the properties of matrices over finite fields, particularly those studying abstract algebra or number theory.
Justabeginner
Let R be the ring of all 2*2 matrices over Zp, p a prime,. Show that if det(a b c d) = ad - bc ≠ 0, then (a b c d) is invertible in R.
I don't know how to start if Zp, with p a prime, is the clause. I know that since ad- bc ≠ 0, it automatically makes the matrix (a b c d) invertible in R.. but does the determinant have to be one?
The most straight-forward way of showing something is invertible is simply find an inverse element and check that it is indeed the inverse. I think there is a very good candidate for the inverse in this case.
A matrix A= (a b c d) has an inverse B = [1/(ad-bc)] (d -b -c a).
Does Zp, p a prime, give any information about the elements of Matrix A, specifically? Does that mean the elements must be prime themselves, or is the determinant prime?...I'm not sure how to focus on what's relevant here.
If ad-bc = 1, then can I prove something about the prime nature of a, b, c, d?
For one thing, it ensures that ##1/(ad - bc)## exists as long as ##ad - bc \neq 0##. This would not be true in general for ##Z_n## where ##n## is not prime. (For example, in ##Z_4##, the element ##2## has no inverse.) What is special about ##Z_p## for prime ##p##?
One thing to note is that in the set of real numbers, 1/(ad-bc) is an inverse of ad-bc provided that ad-bc is not equal to 0.
Zp is a field if and only if p is prime.
Suppose p, prime, where P>=2. and Zp = {0, 1,...p-1}
Zp satisfies field axioms of closure, commutativity, and associativity by addition through integer properties. Additive identity also exists as in integers. Additive inverse also exists: For x in Zp, take -x(mod p). Then x + (-x) = 0 mod p.
Closure under multiplication also occurs since for x and y in Zp, xy mod p in Zp exists.
Commutativity, associativity, and identity of multiplication also exists by property of integers.
For x in Zp, the multiplicative inverse 1/x cannot occur in Zp. So ax + bp = 1
Then ax= 1 mod p
So, a is the multiplicative inverse of x.
If p is not prime, then Zp is not a field.
Since p is not prime, p= mn where m,n ≠0 and m,n≠1. If Zp is a field, then m would have a multiplicative inverse such that mm-1= 1.
Then n*1 = n *(mm-1) = (mn)m-1 = pm-1 = 0.
But n≠0, so proof by contradiction holds.
Zp cannot be a field if p is not prime.
Yes, that's correct. Every nonzero element of ##Z_p## has an inverse if and only if ##p## is prime. This is true of matrices, too: if we were working in ##Z_4##, for example, then the matrix
$$\begin{pmatrix}2 & 0 \\ 0 & 2\end{pmatrix}$$
would have no inverse.
How may I 'show' that the matrix has an inverse then? Using a property of a field?
You could show that there is no matrix ##\begin{pmatrix}a & b \\ c & d\end{pmatrix}## satisfying
$$\begin{pmatrix}2 & 0 \\ 0 & 2\end{pmatrix}\begin{pmatrix}a & b \\ c & d\end{pmatrix} = \begin{pmatrix}1 & 0 \\ 0 & 1\end{pmatrix}$$
This is clear if we simply carry out the matrix multiplication on the left hand side. Indeed, multiplying the first row of ##\begin{pmatrix}2 & 0 \\ 0 & 2\end{pmatrix}## by the first column of ##\begin{pmatrix}a & b \\ c & d\end{pmatrix}##, and setting equal to the ##(1,1)##'th element of the right hand side, we get the equation ##2a = 1##, which has no solution in ##Z_4##.
[edit] Sorry, I misread your question. I thought you were asking how to show that ##\begin{pmatrix}2 & 0 \\ 0 & 2\end{pmatrix}## has no inverse in ##Z_4##.
To show that a matrix ##M## DOES have an inverse, it suffices to find another matrix ##X## such that ##MX = I##.
As you said above, if you start with an arbitrary matrix ##\begin{pmatrix}a & b \\ c & d\end{pmatrix}##, then
$$\begin{pmatrix}a & b \\ c & d\end{pmatrix}\begin{pmatrix}d & -b \\ -c & a\end{pmatrix} = \begin{pmatrix}ad-bc & 0 \\ 0 & ad-bc \end{pmatrix}$$
Now if ##ad-bc## is nonzero, then it has an inverse since ##Z_p## is a field. Call this inverse ##1/(ad-bc)##. Now multiply both sides by ##1/(ad-bc)## to obtain the result you need.
  • · Replies 20 ·
  • · Replies 25 ·
