SMUDGY
- Messages
- 20
- Reaction score
- 0
Special lamps may be purchased to help plants grow indoors. These lamps produce light with wavelengths comparable to natural sunlight. A manufacturer wishes to check these lamps by measuring the out put of the lamp at different wavelengths.
The above is the scenario given
You are required to design a laboratory experiment using a light dependent resistor (LDR) to investigate how the intensity of light emitted by a lamp varies with wavelength.
The requirement of what i need to do above
A diagram of the arrangement of your apparatus, and in your account you should pay particular atttention to
a. the procedure to be followed
b. how the wavelength of the light falling on the LDR is determined
c. how a measure of the intensity can be obtained from the LDR.
d. the range and precision of any instruments that would be used
e. the factors that would need to be controlled to ensure that it is a valid test
f any safety precautions you would take when carrying out the investigation
g particular features of the design that would ensure the accuarcy and reliability of your results.
The above is the crucial content that i need to put into my report
