Is a finite semigroup isomorphic to subsets of some group?
Stephen Tashi
Education Advisor
Is any given finite semigroup isomorphic to some finite semigroup S that consists of some subsets of some finite group G under the operation of set multiplication defined in the usual way? (i.e. the product of two subsets A,B of G is the set consisting of all (and only) those elements of G that result from multiplying some element in A times some element in B using the group operation defined on G).
A necessary condition is of course that the semigroup is cancellative, since groups have this property: http://en.wikipedia.org/wiki/Cancellative_semigroup So this means that ##ax = bx## implies ##a=b## and ##xa = xb## also implies ##a=b##.
If the semigroup is abelian, then the Grothendieck construction gives an explicit group where-in the semigroup is embedded. So for abelian semigroups, this is an equivalence.
Now, it turns out that any finite cancellative semigroup is already a group. So the answer to your question is that any finite semigroup that can be embedded in a group, is already a group. The latter is easily seen directly: let ##G## be a group and let ##S## be an embedded semigroup. Take an element ##a\in S##, then
\{a,a^2,a^3,a^4,...\}\subseteq S
Since ##S## is finite, there exists some ##n\neq m## such that ##a^n = a^m##. Say that ##n>m##, then ##e = a^{n-m}\in S##. Furthermore, ##a^{n-m-1}## is also in ##S## and this is an inverse.
Likes 1 person
That was a very useful reply - and quick too!
I'm not clear yet on what an "embedding" must be and whether my question is more general than asking for an embedding.
I agree that groups have the cancellative property, but does a semigroup whose elements are subsets of group (rather than being necessarily single elements of the group) have the property? For example, the usual definition for multiplying sets of group elements would make \emptyset behave like a zero element. The presence of a zero would screw up cancellation.
So you have a group ##G##, and you take ##\mathcal{P}(G)## and you put a product on there that says ##AB = \{ab~\vert~a\in A,~b\in B\}##? Then no, this does not have the cancellative property since ##GG = G = \{e\} G##.
I don't know the answer to your question. But it is important to note that the subsets of some group have a partial ordering relation given by ##\subseteq##, such that if ##H\subseteq H^\prime##, then ##HK\subseteq H^\prime K##. So the order agrees with the multiplication operation.
So any semigroup that is isomorphic to the subsets of some group would have to admit such an order relation.
For abelian groups we can even say more and we can add that any two elements under the order relation must have a supremum.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
