Is Acceleration of Acceleration a Valid Concept in Physics?
  • Thread starter Thread starter Trepidation
    Acceleration
Acceleration is defined as the rate of change of velocity, measured in m/s². The concept of "acceleration of acceleration" leads to higher derivatives, such as jerk (m/s³) and jounce (m/s⁴), though their practical applications are limited. Jerk is relevant in specific fields like engineering, particularly in rollercoaster design, while jounce has even less utility. Despite mathematical expressions for these higher derivatives, their physical significance is often questioned. Overall, while the acceleration of acceleration exists mathematically, its practical relevance diminishes with each successive derivative.
Trepidation
Acceleration is motion at a velocity that is in a consistent state of change, right? So...
v is in terms of m/s
a is in terms of m/s^2
So what is motion at an acceleration that is in a consistent change?
a^2 is in terms of m/s^3
or
a^2 is in terms of m/s^4
Is this 'acceleration of acceleration' ever used? Howabout acceleration of acceleration of acceleration, etc etc ad infinitum?
or
Just because something has a mathematical expression doesn't mean it is automatically physically useful or meaningful.
Zz.
Zz.
I know... The first part of my question was what the mathematical expression would be, and the second part was whether it would or would not be physically useful.
or
I don't think it's a^2 you want.
\vec{j} = \frac{d\vec{a}}{dt} = \frac{d^3\vec{x}}{dt^3}
j is called 'jerk' (or sometimes 'jolt') and has units of m/s^3.
In physics jerk is rarely used, though in some areas of engineering (rollercoaster design would be the usual example) it is important.
The quantity:
\frac{d\vec{j}}{dt} = \frac{d^4\vec{x}}{dt^4}
is often called 'jounce' and has even more limited use than jerk. Obviously you can keep on taking higher derivaives of dispalcement with respect to time without limit, but generally the higher the derivative the less it's use.
Thank you very much...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
