What's the Difference Between Amplification and Gain?
Amplification and gain both refer to the increase or decrease in the amplitude of a signal, but they have distinct meanings in electronics. Amplification is a general term for any change in amplitude, while gain specifically measures the ratio of output to input signal, typically expressed in decibels (dB). The discussion clarifies that a gain of 3 from 5V to 15V represents a 200% increase in voltage, not 300%. Additionally, the correct formula for voltage gain is 20 * Log(Vout/Vin), while power gain is calculated as 10 * Log(Pin/Pout). Understanding these differences is crucial for accurate signal processing and analysis.
JJ91
Hello,
I can't figure out what's the difference between the two:
Gain - how much the amplitude of the signal was increased/decreased
Amplification - how much the amplitude of the signal was increased/decreased
If we take a basic inverting amplifier circuit:
http://alturl.com/39n78
We can see an amplification of signal by 3 times from 5V to 15V
This is equivalent increase of 300%
300% to dB would mean a gain of 4.77dB according to http://www.lightmachinery.com/percent-to-dB-conversion-calculator.php
Is gain (dB) simply an amplification rate in different units?
Thanks.
First of a gain of 3 from 5V to 15V is not a 300% increase, it's a 200% increase. Yes, the calculator you reference does show that a gain of 3 is 300%, but that's not the same as a 300% increase. A 100% increase would be an increase from 5V to 10V. Second the dB calculator is calculating power increase not voltage increase. Power gain varies as the square of voltage increase. A voltage gain of 3 would have a dB value of 9.54 dB.
Gain is often expressed as dB so the gains of multiple stages of other elements can be added together instead of multiplied or divided. It's not different units, it's a different mathematical operation. For voltage gain you should use the formula 20 * Log(Vout/Vin).
amplification is what is "occurring ... the gain figure quantifies the amount of amplification occurring
skeptic2 said:
...Gain is often expressed as dB so the gains of multiple stages of other elements can be added together instead of multiplied or divided. It's not different units, it's a different mathematical operation. For voltage gain you should use the formula 20 * Log(Vout/Vin).
and to follow on from skeptic2's formula above ...
power gain = 10 * Log (Pin/Pout)
Dave
Super simple, thanks.
Hello,
Thank you for your question. To answer your question simply, yes, amplification and gain are essentially the same thing. Both terms refer to the increase or decrease in amplitude of a signal. However, there are some technical differences between the two terms that are worth noting.
Amplification is a more general term that refers to any increase or decrease in the amplitude of a signal. It can be used to describe the increase in voltage in an electronic circuit or the increase in volume in an audio system. Gain, on the other hand, is a more specific term used in the field of electronics and signal processing. It is a measure of the ratio of output signal to input signal and is usually expressed in decibels (dB). In your example, the gain of the amplifier circuit would be 4.77dB, which means the output signal is 4.77 times larger than the input signal.
In summary, amplification and gain are similar concepts that describe the increase or decrease in amplitude of a signal, but gain is a more specific term used in electronics and is measured in decibels. I hope this helps clarify the difference between the two terms. Let me know if you have any further questions.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
