Is Biot-Savart law the only way to calculate energy density of magnetic fields?
The discussion revolves around the calculation of energy density in electromagnetic fields, specifically questioning the validity and exclusivity of the Biot-Savart law in this context. Participants explore various formulations of energy density, the relationship between electric and magnetic fields, and the implications of different mathematical approaches.
  • Some participants question the traditional assumption that electromagnetic field energy density is given by w = \frac{1}{2}(E^2+B^2), suggesting that other functions could also satisfy the continuity equation.
  • One participant argues that the relationship between the magnetic field and velocity complicates the calculation of work done, indicating that the formula presented may be incorrect.
  • Another participant explains that the energy density for electric and magnetic fields arises from integrating specific potentials and densities, leading to established expressions for energy density.
  • Some participants acknowledge the need for consistency with known energy densities of static electric and magnetic fields, suggesting that this limits the arbitrariness in choosing w.
  • Concerns are raised about the omission of the velocity vector in the initial formula, with participants emphasizing its importance in the context of magnetic fields and forces.
  • One participant asserts that the Biot-Savart law is not universally applicable and does not calculate the magnetic vector potential, challenging its role in deriving energy density.
  • Another participant argues that energy density is fundamentally linked to potential energy and that the relationship with charge velocity cannot be ignored in calculations.
Participants express multiple competing views regarding the validity of the initial formula for energy density and the role of the Biot-Savart law. The discussion remains unresolved, with no consensus on the correct approach or formulation.
Participants highlight the dependence of energy density expressions on various assumptions, including the treatment of charges and their motion, as well as the limitations of the Biot-Savart law in certain contexts.
paweld
I wonder why we always assume that electromagnetic field energy density is
[tex]w = \frac{1}{2}(E^2+B^2)[/tex]. In fact energy of the filed can be any
function [tex]w[/tex] for which there exists such vectror field [tex]\vec{S}[/tex] that
continuity equation is fulfilled:
[tex]\vec{E} \vec{J}+\frac{\partial w}{\partial t}+\nabla \vec{S}=0[/tex].
Where [tex]\vec{E} \vec{J}[/tex] is a work donw by the filed in unit volume and time.
Obviously we can choose: [tex]w = \frac{1}{2}(E^2+B^2)[/tex] and
[tex]S =\vec{E}\times \vec{B}[/tex] but there are also other options.
Because [tex]\frac{\partial \rho}{\partial t}+\nabla \vec{j}=0[/tex] ([tex]\rho[/tex] - density
of charge, [tex]\vec{j}[/tex] - density of current) we can take for example:
[tex]w = \frac{1}{2}(E^2+B^2) + \alpha \rho[/tex] and [tex]S =\vec{E}\times \vec{B} + \alpha\vec{j}[/tex].
This change doesn't affect the continuity equation and of course both [tex]\rho[/tex] and [tex]\vec{j}[/tex] can by express
by means of Maxwell equation in terms of [tex]\vec{E}[/tex] and [tex]\vec{B}[/tex]
so that [tex]w[/tex] and [tex]\vec{S}[/tex] depend only on the field.
Are there any physical arguments for [tex]w = \frac{1}{2}(E^2+B^2)[/tex] or it's
only our traditional choice and others are as well.
Magnitude of magnetic field B is proportional to the velocity and have geometrical relations with this vector that E does not have, therefore my conclusion is that your equation is indeed wrong, and having E and B forces acting in different (perpendicular) directions might be serious problem to calculate 'work done'. Also, I could not find that formula in Wikipedia, but I suppose some article there must say something more about the origin of that equation.
These stem from the separate derivations of W for electric field and magnetic fields. W for electric field results from integrating the product of electric potential and charge density over all space and W for magnetic field from integrating the scalar product of magnetic vector potential and current density vector. As a result of these integrations, W for electric field calculates to e0 E2/2 per unit volume and W for magnetic field is B2/2u0 per unit volume.
Yes, you are right jackiefrost. I didn't take into account that we know the energy of
static electric and magnetic energy density and these formula should be consistent.
This removes the arbitrariness in choice of w.
But I think that there should exist also some relativistic arguments for this particular choice.
Hold on a second.
There is this velocity vector having very intimate relation with the magnetic field. Both, magnetic field and magnetic force magnitude are proportional, and perpendicular, to the velocity vector, so where is this 'v' in that formula, where did it go?
That can mean only one thing - use Biot-Savart law to calculate magnetic field potential and Lorentz force equation to calculate magnetic force (on a "test particle"), except that you seem to be talking about "current in a wire", so the 'velocity' should be integrated via amperes, like this:
In any case, the equation in the opening post can not be valid, there is no way that can be derived without keeping the relation between magnetic field, as well as magnetic force, with the velocity vector. Also, how can scalar help you with calculating work done, especially if displacement was in perpendicular direction to the flow of the current?
The equation given by the OP are indeed correct. I'm not sure what you are trying to do here but it isn't correct. This expression is for the energy density of the electric and magnetic fields, charges do not come into this. If you wanted the energy density of sources they would be something like the product of the potentials and currents.
Second, the Biot-Savart law is not correct except in the quasi-static limit. Third, the Biot-Savart law does not calculate the magnetic vector potential.
The energy density of the field is basic introductory electromagnetics.
Energy density is nothing more but 'potential energy' aka field potential like with gravity, only per volume area instead of per point particle, it is "approximated" with Biot-Savart in either case.
Of course charges come into this, where else would you get electric fields from, and if those charges did not move, where else would you get magnetic fields from?
If not Biot-Savart, then what equation do you suggest was used to derive that formula, is there any such equation for magnetic field magnitude that is not related to charge velocity?
So, what I'm trying to do is to point out that energy density of the magnetic field is related to the velocity and this relation is missing from that equation. In other words, I do not think you, or anyone, can derive it and cancel out velocity variable, nor can energy density of magnetic field be calculated without Biot-Savart law. Just try and calculate energy density of a single electron's magnetic field and see what equations will you end up.
  • · Replies 0 ·
