Is blue shift a potential problem for near light speed travel?
Future spaceships traveling near light speed may face significant radiation challenges, including blue-shifted starlight becoming harmful. The Doppler effect can shift wavelengths from visible light to gamma rays at speeds approaching light, requiring calculations to determine the necessary velocity. At a speed of 0.9992c, starlight could shift to X-rays, posing a lethal radiation risk over extended periods. However, proximity to bright stars like the sun drastically increases radiation exposure, with lethal dosages possible in mere seconds. Thus, blue shift and radiation from starlight are critical considerations for near-light-speed travel.
superpaul3000
I've heard that future spaceships traveling at near the speed of light will have to deal with massive amounts of radiation due to interstellar gas. I think these spaceships might also have to deal with radiation from star light being blue shifted. How close to the speed of light would one have to get in order for the little bit of star light that exists to be blue shifted to gamma rays? What energy would the photons need to be blue shifted to so that they would become deadly to humans?
Science news on Phys.org
Doppler effect .
lambda=sqrt((1-q)/(1+q))*(lambda2)
where q=v/c and lambda is the final shifted wavelength and lambda2 is the initial wavelength , so you could then calculate how fast you would need to go to shift the light from blue light to gamma rays .
Using the max precision my calculator goes to (not sure what that is) I get q = 1, so you'd have to be going extremely close to the speed of light.
yes you would
I guess this would not be that big of a problem until the spaceship got near a star. Given the amount of light incoming from the stars in the night sky it would take 370,000 years for a human to acquire the lethal radiation dosage (if they are traveling at 0.9992c which would blue shift star light to x rays). However traveling at that speed toward the sun, at 1 AU you would get the lethal dosage in 0.005 seconds.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
