Is conservation of energy derived from the work energy theorem?
The discussion revolves around the relationship between the work-energy theorem (WEP) and the principle of conservation of energy (COE). Participants explore whether one is more fundamental than the other and how they relate to different energy transfer scenarios, including heat and internal energy. The scope includes theoretical considerations and implications for various physical systems.
  • Some participants propose that the work-energy theorem and conservation of energy can be viewed from two distinct approaches: one focusing on work done and the other on energy changes within a defined system.
  • Others argue that the work-energy theorem is limited in its ability to describe energy entering or leaving an object, particularly in systems involving heat transfer.
  • A participant mentions that the work-energy theorem may not adequately account for internal energy, especially in systems like springs.
  • Some contributions suggest that while the work-energy theorem holds for all forces, it primarily describes changes in kinetic energy rather than total energy changes.
  • There is a discussion about whether the work-energy theorem can be considered as fundamental as conservation of energy, with varying subjective assessments of their relative fundamental-ness.
  • A later reply questions the validity of equating work done to changes in potential energy in certain scenarios, emphasizing the need for a broader perspective on energy conservation.
Participants do not reach a consensus on whether the work-energy theorem is as fundamental as the conservation of energy. Multiple competing views remain regarding the limitations of the work-energy theorem and its applicability to different physical situations.
Some participants highlight limitations in the work-energy theorem's applicability, particularly regarding heat and internal energy, and note that certain assumptions may not hold in all scenarios. The discussion also reflects on the need for careful definitions when discussing energy conservation in various contexts.
  • #31
etotheipi said:
However, doesn't the work energy theorem only account for kinetic energy?
Yes. That is precisely the issue with treating it as something fundamental and trying to derive conservation of energy from it.
etotheipi said:
We could always then set ##W_c = -\Delta U## to get out potential energy terms.
Certainly, but then you are no longer using the work energy theorem as the fundamental rule to derive the conservation of energy. I understood that was the idea of your OP, correct?
  • #32
jbriggs444 said:
A deformable body would include, for instance, a spring. Which can contain energy other than kinetic.
But in the same vein as earlier, we might conceptually consider the work done on each particle in the spring individually by internal forces between other particles, external forces etc.
This would give us our hypothetical statement of the work energy theorem for a spring. Except the conservative work terms due to the interactions between the particles which produced the "springiness" we replace with negative change in potential energy terms.
For instance, we might have two point masses attracting each other gravitationally as our system, ##m_1## and ##m_2##. The system as a whole, we might think of as a deformable body. For ##m_1##, ##W_{12} = \Delta T_{1}##, and for ##m_2##, ##W_{21} = \Delta T_{2}##. Then if we sum those, since ##W_{12} + W_{21} = -\Delta GPE##,
##W_{21} + W_{12} = \Delta T_1 + \Delta T_2 = -\Delta GPE \implies \Delta T_1 + \Delta T_2 + \Delta GPE = 0##
  • #33
Ah, okay. I suppose my original question was a little misleading. Apologies!
  • #34
Right. But then it is no longer being treated as a deformable body!
The point of calling it a "deformable body" and modelling it as such is that it becomes a black box that you are no longer allowed to peek inside. If you have to peek inside to see the particles and ignore the interaction forces between them, the box is no longer black. You are not treating it as a deformable body any more.
  • #35
Right, I now understand. Thank you for your patience!
  • #36
Ok, so now I am thoroughly confused. What is your intention/goal? In particular regarding the “fundamental-ness” of the work energy theorem and the conservation of energy.
  • #37
Dale said:
Ok, so now I am thoroughly confused. What is your intention? In particular regarding the “fundamental-ness” of the work energy theorem.
It's more because I'm working from Kleppner and Kolenkow, and they gave a proof of the conservation of mechanical energy via the work energy theorem. And quite a few introductory mechanics textbooks sidestep into conservation of energy in the same way, after first integrating Newton's second law.
This seemed a little odd, not least since you mentioned that there are other pathways for transfer of energy within a system. And to make matters worse, different authors all treat energy slightly differently. Morin/Halliday/Sherwood all make extensive reference to the concept of defining systems and treating energy transfers across the boundary, whilst others will derive most energy relations directly from the work energy theorem.
So really I'm finding it's just a little bit of a chicken and the egg situation. I think now I've come to the conclusion that work-energy and the first law of thermodynamics approaches are distinct, though similar. And one can derive special cases of one from the other.
I do apologise for being daft, and many thanks for your help on this!
  • #38
The conservation of energy is far more general than the work energy theorem, so I am skeptical that such a derivation is valid. Either you must add something beyond the work energy theorem itself to make the derivation more general or you must limit the derivation to a restricted set of situations in order to apply the theorem.
However, as a pedagogical tool I could see the value. Generally net forces are introduced before energy is introduced, so you can point out conservation of energy as being implied by things they already know. In the pedagogical case the fact that it is not a general derivation is fine, it is just a motivational example and does not need to apply generally.
  • Love
  • #39
Just to close off the thread, I'll summarise in light of @jbriggs444's post.
The total work done on any system equals the change in kinetic energy of that system.
However, for particles and rigid bodies the total work equals the external work (there is no internal work), whilst for deformable bodies the total work equals the external plus the internal work.
So we can only write "The total external work done on a particle/rigid body equals the change in kinetic energy of that body".
This is usually what we're interested in when we do a mechanics problem.
  • #40
conservation of energy is true, you can simply consider the ideal gas law
https://en.wikipedia.org/wiki/Ideal_gas_law
if you consider adiabatic compression (i.e. all the energy is contained within the gas even if it is compressed)
https://en.wikipedia.org/wiki/Adiabatic_process
the equations are like :
p1 . v1 = p2 . v2.
so in compression you can have v2 being smaller than v1 and pressure goes up, and in addition the gas actually become hotter (temperature rises). But all that is still contained within the volume of gas.
this is most often used to model cylinders in internal combustion engine or air compressors.
for rigid bodies, it is often considered for the whole body itself as kinetic or potential energy gained. As you normally don't tear apart the atoms and that they stay in place, no work is done between them.
  • #41
Also, just as a further thought, is it possible to show mathematically that internal, non-conservative forces cannot change the total energy of a system?
For internal conservative forces we might say that the work done equals the negative of a change in some potential energy, thus conserving the total mechanical energy.
However, internal non-conservative forces can change the mechanical energy but not the the total energy. I'm not sure how to show this. Perhaps because any such forces will occur in pairs, and their points of application will move through the same displacements?
  • #42
i think the one of the roots for conservation of energy starts in the
First law of thermodynamics
"For a thermodynamic process without transfer of matter, the first law is often formulated
$$\Delta U = Q - W$$ where ΔU denotes the change in the internal energy of a closed system, Q denotes the quantity of energy supplied to the system as heat, and W denotes the amount of thermodynamic work done by the system on its surroundings. An equivalent statement is that perpetual motion machines of the first kind are impossible."
i think at one point it goes down to the atoms
https://en.wikipedia.org/wiki/Maxwell–Boltzmann_distribution
  • #43
As far as I know there is no phlogiston, although it does supply a useful discription in a certain realm.
I make the same statement about heat. One can argue that the realm of its utility is larger, but elevating it to something "fundamental" seems the root of much evil. It provides the rug under which we sweep all of the processes we do not wish to consider in detail. And it did work pretty well for Carnot.
But to worry about the fundamental nature of "what is heat" and "what is work" "what is internal energy" etc seems folly to me. It depends upon how you choose to cut the world into subsystems The (mis?)statements of the work energy theorem and the seeming endless arguments so generated derive from arbitrarily truncated definitions of the system and witting or unwitting ignorance of relevant degrees of freedom. They can be "internal" or "external" When those degrees of freedom are not coupled to the problem or are otherwise isolated this sometimes works fine.
For frictional "forces" we choose to ignore the details of atomic motion and interaction at interfaces and then make up a phenomenological force. Small wonder it isn't simple. Amazing how useful it is.
Deformable bodies we can occasionally subdivide into chunks and get away with it (like a spring, for instance). The system complexity goes up as the chunks get smaller.
While this subterfuge provides a useful framework for approximation we should not be surprised when it produces seeming inconsistencies because of the parts left out.
So my answer to the original OP
etotheipi said:
To my mind, there are two distinct approaches to energy problems that different authors tend to use, and I wondered whether either is more fundamental than the other.
They apply to approximations to reality, and each has a locus of utility, neither being "more" fundamental.
But energy is conserved. That is fundamental.
  • Love
  • #44
No.
The work energy theorem (as applied to point particles) is a mathematical consequence of Newton's second law. In that context, "energy" is defined as ##E=\frac{1}{2}mv^2## and work as ##W=F \cdot ds##.
Now you want to ask about energy conservation for some arbitrary non-conservative force. Before you can do that, you have to come up with a relevant definition for "energy". Does this non-conservative force draw down a supply of electricity from a D cell? Does it burn gasoline from a tank? Does it draw from a pool of magic? If energy is not conserved, it doesn't have to draw from anything at all. Mathematics does not know which until you tell it with an axiom.
  • #45
jbriggs444 said:
Now you want to ask about energy conservation for some arbitrary non-conservative force. Before you can do that, you have to come up with a relevant definition for "energy". Does this non-conservative force draw down a supply of electricity from a D cell? Does it burn gasoline from a tank? Does it draw from a pool of magic? Mathematics does not know until you tell it with an axiom.
Okey dokey, `what if I define the total energy to be the sum of the mechanical energy and internal energy of the system. More concretely, the sum of the kinetic energies of all the particles in the system and the potential energies associated with each pair of particles in the system.
It is a statement of the conservation of energy that in the absence of external work and heat, this total energy remains constant. For that to be true, the total work done by non-conservative internal forces must be zero.
  • #46
Because those non-conservative forces are somehow connected to degrees of freedom "outside" the system (might actually be internal and tiny ). This tautological argument is simply one of semantics and not physics. Energy is conserved.
  • #47
Just in case anyone was still interested, I came up with the following. For any system,
##W_{ext} + W_{int,nc} + W_{int, c} = \Delta T##
##W_{ext} + W_{int,nc} = \Delta T + \Delta U = \Delta E##
Where ##U + T## is the total energy in the system, kinetic plus potential, no matter whether it is microscopic or macroscopic. However, we know from the first law of thermodynamics that in the absence of heat,
##W_{ext} = \Delta E##
So we are forced to conclude that ##W_{int, nc} = 0##, which is the desired result.
This might well be a circular argument, however if the other assumptions are true then it sure seems that internal non-conservative forces can do no net work on a system.
Which is nice, anyway, since otherwise we could have an isolated system whose total energy changes due to internal actions, which is obviously wrong!
  • #48
I am pretty sure it is. You have assumed conservation of energy in order to deduce that non-conservative internal forces must have an associated reservoir of something that gets lumped in as "internal energy". As a result, these internal forces conserve energy even though they are non-conservative.
  • #49
It was my understanding that for an isolated system (no external work done/heat), mechanical energy is conserved if there are no internal non-conservative forces.
Whilst, also for an isolated system, the total energy (mechanical + thermal) is conserved even in the presence of internal non-conservative forces. Often these will be dissipative, so will funnel mechanical energy into internal energy.
You're right, it's definitely a circular argument. However it does show that if we take conservation of energy in its current form to be true, which I believe is generally accepted, then the total work of internal non-conservative forces must be zero. Even if the contribution of each individual force is non-zero.
  • #50
It shows that no matter where Dennis the Menace puts his blocks, there is a number somewhere that accounts for them.
https://www.feynmanlectures.caltech.edu/I_04.html
  • #51
That too :cool:
I like to think of the example of a block sliding down a rough ramp, and we might consider the Earth-ramp-block as one isolated system.
The total work done on the system by internal conservative forces manifests itself as (negative changes in) gravitational potential energy, and some other forms (i.e. the potential energy component of some thermal energy, etc.)
But non-conservative internal forces, like the friction between the block and the ramp, will each do some amount of work. The total work done by all forces of this type, however, must be zero.
Like you say, Dennis can't start creating blocks out of thin air.
  • #52
You can derive conservation of mechanical energy from the work-energy theorem, but you cannot derive conservation of energy. How could it even be possible to do so given the fact that the work-energy theorem follows from Newton's Laws, but Conservation of Energy is a grand principle that includes not just Newtonian mechanics but also thermodynamics? It wasn't until the 19th century that the Conservation of Energy was established, and even as recently as the 1890's it appeared to be in serious doubt because Madame Curie was using rocks (of radium ore) to raise the temperature of water in a calorimeter.
  • #53
By the modern definition of "energy" the conservation of energy follows from time-translation invariance of Newtonian, Minnkowski and static general-relavistic spacetimes. Noether's theorem tells you what energy precisely is within the model. If the symmetry is not realized by the model, you cannot define energy nor is there a conservation law.
  • #54
I came across this whilst reading around, but I think it's going to be a good few years at least until I can understand what it's all about. Something about symmetry under translation in time (?).
Gotta learn the calculus of variations first...
  • #55
From a brief look through the relevant chapter I would say that K&K derive the work-energy theorem for a point particle only. And do not generalise it to a system of particles - not that I can see.
The end of the chapter includes a discussion of conservation of energy more generally.
I also found this, which refers to a generalisation to a system of particles (Morin) and includes the additional terms for internal energy:
https://physics.stackexchange.com/questions/247303/work-energy-theorem-for-a-system
  • #56
I also had a look through Morin (and that PSE link) and generally like how he sets the topic out. The only wrinkle is this annoying internal non-conservative work term which I don't seem to know how to get rid of. Even if I take the system to be completely isolated, I can write the change in total potential and kinetic energy as so (taking into account all interactions, microscopic and macroscopic, so no internal-mechanical distinctions yet),
##W_{int, c} + W_{int, nc} = \Delta T \implies \Delta U + \Delta T = W_{int,nc}##
However, we know that for such an isolated system, ##\Delta U + \Delta T = \Delta E## should be zero no matter what, since it is ridiculous to suggest that the system can be gaining energy from internal actions. So the only conclusion is that ##W_{int, nc} = 0##.
Then, I though we could impose an arbitrary classification into macroscopic and microscopic terms in order to setup the "internal energy" term,
##W_{int, nc, mac} + W_{int, nc, mic} + W_{int, c, mac} + W_{int, c, mic} = \Delta T_{mic} + \Delta T_{mac}##
This leads to
##W_{int, nc, mac} + W_{int, nc, mic} = \Delta T + \Delta U + \Delta E_{th} = \Delta E_{mech} + \Delta E_{th}##
However this doesn't seem to help me that much, since really internal non-conservative forces should be responsible for transfers between ##E_{mech} \leftrightarrow E_{th}##.
This would suggest a relationship like ##\Delta E_{th} = -\Delta E_{mech}##, which is induced by internal non-conservative forces. However, in such a way that ##W_{int, nc} = 0##. This is completely confusing.
I've been playing around for a day or so but wonder if I'm wasting my time. Every undergrad textbook I've consulted on the matter (e.g. Halliday/Resnick) state that mechanical energy of an isolated system is conserved in the absence of internal non-conservative forces, whilst total energy of an isolated system is conserved regardless. I wonder if this just needs to be taken as an empirical fact, since I'm at a loss on how to derive it!
  • #57
One possible answer is that there are no non-conservative forces.
  • #58
Though I might consider a rigid block sliding across a rough surface, and take the system to be the block and the surface. A frictional force acts on both the block and the surface.
In this example, it is fairly clear that the KE of the block is reducing, so the mechanical energy of that system is reducing. The frictional force of the block on the surface also results in the thermal energy of the surface increasing.
Since the displacements of the two forces are equal, it is fairly evident that the total work done by the two frictional forces (which are internal, non-conservative) is zero. And that ##\Delta E_{mech} = -\Delta E_{th}##.
But we'd need to generalise this somehow.
Or do you mean that all of those non-conservative forces are actually conservative?
  • #59
To phrase it slightly differently. If there is an internal non-conservative force, then there must be a "fundamental" non-conservative force. I.e. some fundamental interaction that leaks energy out of the universe in some way. That essentially is a necessary condition for (loss of) conservation of energy.
That's why, I believe, Feynman says:
"There is a fact, or if you wish, a law, governing all natural phenomena that are known to date. There is no known exception to this law—it is exact so far as we know. The law is called the conservation of energy. "
Your non-conservative internal force would be an exception to this.
  • #60
PeroK said:
To phrase it slightly differently. If there is an internal non-conservative force, then there must be a "fundamental" non-conservative force. I.e. some fundamental interaction that leaks energy out of the universe in some way. That essentially is a necessary condition for conservation of energy.
That's really interesting, I just wonder how then we might rationalise the frictional forces between the block and the surface. If we do break it down into electric interactions between the atoms at the interface between the surface, then we could technically attribute all of that work to microscopic internal potential energy.
I think you're right that a different approach is required. Clearly just fiddling around with algebraic work terms like I've done doesn't give any insight.
If only Dennis the Menace could tell us where all of his blocks are. I think I'll take a break for a bit and try to come back to it with a fresh outlook. I'll try and think on your suggestion.
  • · Replies 19 ·
  • · Replies 77 ·
