etotheipi
To my mind, there are two distinct approaches to energy problems that different authors tend to use, and I wondered whether either is more fundamental than the other. The first is variations on the work energy theorem, and the second consists of defining a system boundary and setting the change in total energy of that system (kinetic, potential, thermal) to the external work done on all components of the system.
I thought about it and came up with the following. For any particle or rigid body in a system of particles or rigid bodies respectively, we can write down a work-energy equation (which follows directly from Newton II) $$\sum_{i} W_{i}= \Delta T$$ Then, we sum all of these equations for each particle in the system. For any overlapping terms due to inter-particle interactions, we can replace it with a potential energy, ##W_{jk} + W_{kj} = \Delta U_{jk}##. The sum of all of the changes in kinetic energy results in the total change in kinetic energy, which can be decomposed into macroscopic and microscopic terms. This would lead to a final equation, $$W_{ext} = \Delta T + \Delta U + \Delta E_{th} = \Delta E$$which is what I often see written for conservation of energy. For instance, if we take the example of a block being pulled up a rough plank by a rope, it appears there are two ways of looking at it
I've read that energy conservation can be derived more fundamentally via Noether's theorem, however wondered whether the the ideas set out above are correct?
- Direct application of the WEP: ##W_{tension} + W_{friction} + W_{weight} = \Delta T \implies W_{tension} + W_{friction} = \Delta U_{grav} + \Delta T##
- Defining a system to be the block and the Earth, thus defining ##E = U_{grav} + T## and letting the external work be ##W_{tension} + W_{friction}##.
