Is electric potential conservative? yes.?
Electric potential is associated with conservative electrostatic fields, which can be represented as the gradient of a scalar potential. The discussion clarifies that a conservative potential leads to conservative forces, emphasizing that it is path-independent and solely dependent on coordinates. Participants debate the definitions of "conservative," with some asserting that any single-valued scalar potential results in a conservative field. The conversation highlights the relationship between electric potential and conservative fields, underscoring the importance of clarity in terminology. Overall, electric potential is confirmed to be conservative in the context of electrostatics.
seto6
is electric potential conservative?
is it correct?
Electrostatic fields are conservative (a conservative field is one that can be represented as the gradient of some scalar potential). Electric potential is a scalar, so I'm not sure what you mean by conservative...what is a conservative scalar?
yes it is a scalar so is it conservative
What definiton of "conservative" are you using?
Conservative potential is a potential that gives rise to conservative force.
Alternatively, it's one that is path independent, and is simply a function of coordinate.
That definition makes no sense. Any single-valued scalar potential will give rise to a conservative field.
All scalars are path independent.
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
